I think I may have pressed on wrong button on my universal remote ...when I turn to the HDTV channels no sound comes from my speackers and the light by the lock button on the receiver comes on. If I turn to the regualr channels( the channels not in High def) I can get sound. It was working fine until I grabbed the remote to change channels and the sound went off the hi def channel
Comments:
May 11, 2008
- Thanks for the info.It resolved by problem. Unplugging it for 10 minutes seems to have fixed the problem.Thanks for saving my rising blood pressure
Try to fix it by pressing the blue MODE button on the Denon remote and make sure it is set to AUTO.
If this doesn't work, then try unplugging it for 10 minutes and plugging it back in and see if that works.
Let me know if neither of the above options works and we can try something else, thanks.
If you get it working, I would appreciate any and all feedback
Comments:
May 11, 2008
- glad it worked, please don't forget to rate my solution and have a good day
May 14, 2008
- Please don't forget to let me know your thoughts about my
solution.
If your problem is fixed, please rate this solution as that is one of the
biggest aspects of how this website works and in order to receive any credit in helping you, I need to be rated.
Otherwise, let me know if you have further questions and I would be glad to
help.
I have Denon AVR 4500, unit works fine but I change function knob it makes loud poping or thump in...
(More)
I have Denon AVR 4500, unit works fine but I change function knob it makes loud poping or thump in the speaker!
the unit was fine yesterday morning...now no sound out on any level or function..ie...
(More)
the unit was fine yesterday morning...now no sound out on any level or function..ie dvd/tuner/tv...what gives? I tried unplugging and replugging still no go is there a "reset" button/switch? someone , anyone please help.The set up is as such I run a Denon 5 disc dvd in, a vcr in, a hdtv cablebox in and a Kenwood 6 +1 cd player and an addl Kenwood recv in...(hardly use that except at Holidays). All was working fine like I said. Thanks, Geoff
I don't get any sound output from my Denon 4800 receiver. It intermittently comes but have been...
(More)
I don't get any sound output from my Denon 4800 receiver. It intermittently comes but have been mostly sound less
Hi, I have a Denon AVR-4800 to which I have connected a pair of Sony ES series CD decks. I'm using...
(More)
Hi, I have a Denon AVR-4800 to which I have connected a pair of Sony ES series CD decks. I'm using the optical connections and have the AVR-4800 inputs set to "Optical1" and "Optical2". The CD decks play fine but I can't figure out why there is no output at the analog Tape1 and Tape2/Mon outputs. In order to record from either CD deck I have to connect the RCA cables between the 4800 and the CD decks. I assumed that I would be able to record from a CD using the optical inputs since the optical/digital sigal is converted to anaolg at some point. Does the 4800 not provide an analog output from optical input sources? Or have I missed something in the setup? Thanks, Jeff
Occasionally, it switches rapidly from "HP-on" to "HP-off" but still no sound...
(More)
Occasionally, it switches rapidly from "HP-on" to "HP-off" but still no sound from speaker outputs. I can get sound from the headphones when they are plugged in. I have owned this receiver since 2001. Any assistance you can provide is appreciated!
