Question about HP Pavilion dv5-1125nr Notebook
Overheating issue - HP Pavilion dv5-1125nr Notebook
    President:
  • 1,851 Answers
First of all clean up using a brush all the air inlets - outlets. If it's possible use air under pressure towards the inlets - outlets AFTER the clean up with the brush. Leave the notebook some minutes to calm. Also keep in mind that using the notebook on the bed with the air inlets - outlets covered with blankets, will create temperature problems.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Sep 03, 2010
  • 6,831 Answers
Hello
OK, this is a fairly common problem. We will now provide you with some steps to either correct or prevent overheating of the unit in the future.
Click HERE to navigate to page.
Let me know if you need any further assistance.
Kind regards
Andrea
Posted on Sep 27, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Hoover all the vents firstly, have you over clocked it? if not the cpu might need reseating with more thermal paste
So my car was started but i forgot it was so i went to start again, then my car starts overheating & and also i had fluid leaking too?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
For car running hot and overheating issues, I suggest to you go through this help links. Click this link below and go through the troubleshooting procedure to take care of the problems: ----Car runs hot? http://howtobyme.blogspot.com/2011/11/car-runs-hot-in-traffic.html
-----------All types of car overheating problems and troubleshooting?
http://technoanswers.blogspot.com/2011/11/all-types-of-car-overheating-problems.html
Car freeze overnight and started overheating while driving?http://technoanswers.blogspot.com/2012/01/car-freeze-overnight-and-started.html-----------Engine Overheats and heater blowing cold?
http://howtobyme.blogspot.com/2011/11/engine-overheats-and-heater-blowing.html
Car overheats and Air blows hot at idle?
http://howtobyme.blogspot.com/2011/11/car-overheats-and-air-blows-hot-at-idle.html
--------overheating? http://schematicsdiagram.blogspot.com/2011/12/buick-century-overheating.html
----------Car engine Overheats and transmission starts slipping?http://schematicsdiagram.blogspot.com/2011/12/car-engine-overheats-and-transmission.html
----------This details will help.Thanks.
Feb 20, 2012 | 1996 Honda Accord
Overheating after driving three miles
I would replace the thermostat. Its a cheap fix and most likely the issue. If you replace the thermostat and are still overheating then you may have a more serious issue. But going 3 miles and overheating sound like the thermostat is not opening up at operating temperature.
Jan 17, 2011 | 1990 Toyota Corolla
Shuts down not allowing Windows XP to start
If the Computer shuts down automatically, then the issue might usually be due to the overheating issues.
The overheating issues develop, if the Cooling Fan in the Computer is malfunctioning.
The Processors are designed to shut down automatically, if there are any overheating issues.
For such issues, it would be better to get the Unit examined at the Service Center.
Replacing the Cooling Fan should resolve the issue.
Hope this helps.
Jul 07, 2010 | Toshiba Satellite A105 Notebook
Compaq presario m2000 overheating, broken fan.
Overheating issues are considered as safety issues and are take very sincerely by Computer manufacturer. Generally, overheating occurs due to any mechanical fault. So, you may contact the customer service of the Computer manufacturer to get any sort of assistance.
Nov 17, 2009 | Computers & Internet
Overheating
You could have several issues here. A blockage in the radiator, bad coolant temp sensor, (not turning the cooling fan on) a bad cooling fan motor. sounds as if maybe one of these may be your primary issue, and the cause of the overheating that originally caused your head gasket problem. Hope this helps
Aug 22, 2009 | 1998 Volkswagen Beetle
Overheating of razor phone
the v3 is known for battery issues. not charging, not holding charge and overheating. my suggesting is get a different model phone. and stay away from razors. they all have battery issues, I know this from multiple customer razor issues. all battery issues.
Jul 22, 2009 | Motorola Mobility RAZR V3
Try to turn on my ps3,after 2or3 sec it turns off and just blinks
HI, the power unit is experiencing some difficulties due the an overheating issue. if the light is turning yellow at any time, this will confirm a overheating issue. Now, if the light is simply turning red and, powering off then system with a red blink, this will confirm a power unit failure. you will need to replace the power unit in this case.
Contact your nearest Sony repair shop of, contact Sony manufacture for this repair.
NOTE(If its a simple overheating issue, you can purchase a cooling device to heel this issue)
Jul 21, 2009 | Sony Playstation 3 (PS3) Console
Gateway hd1700 monitor cuts out
i have the exact same issue. It's more than likely a problem with overheating the mainboard. My issue only differs in that i reseived mine in this condition.
Nov 19, 2008 | Televison & Video
A new xbox360 it over heated and will not work now
To fix my overheating issue I bought myself an N-ter-Cooler that affixes to the back of my Xbox, giving it more fans and alleviating overheating issues.
Now if you're saying it will not turn on anymore after it overheated once, You should call Microsoft and see if its replaceable under warranty because if thats the case, your X-box is probably beyond repair.
May 16, 2008 | Video Game Consoles & Games
HP Pavilion dv5-1125nr Notebook Logo
734 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
