Question about Bush DVD142RC 14 in. TV/DVD Combo
Eject tray stuck
My rca 20 inch tv 20f510td dvd tray is stuck closed.it says open on the screen and neither the remote or the button on the front of the tv work.i have tried unplugging it in the past and it has wroked but not now.any ideass?
    Sergeant:
  • 291 Answers
Turn it [the TV] on its RIGHT side......... slowly press the eject button once every second. Pay attention to gears winning [as if something is trying to catch. If that don't work try it on its LEFT side. The gears have to be on one of the sides. If you continue to have the same problem, u need to replac the PLASTIC gear assembly.
Posted on May 12, 2008
How the remote for rca tv dvd combo works
Got one even better for you: Here is a link to the owner's manual for the entire TV/VCR. The information about the remote, which claims to start on page 5 actually starts on page 7 of the online manual. Here's the link - and it's free:
http://tv.manualsonline.com/manuals/mfg/rca/20f510td.html
Jan 29, 2016 | RCA 20F510TD 20 in. TV/DVD Combo
20F510TD
eject the cd tray and use canned air to clean the inside of the cd/dvd unit, just use stick the nozzle near the opening and give it a through dusting. after that, run a cleaning disc through it a few times.
if that doesn't clear up the problem, the dvd player will need to be serviced, most likely either a lens replacement or re-alignment.
hope this helps,
trin
Nov 20, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Rca model 20f510td. parental lock
Hello
You must have its original remote control to unlock the parential lock. If you haven't it with you now, try to buy it or gather it from any of your friends or relatives who owns the same model; just to unlock it. After unlock, you can use universal remote or so.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
OK.
Jul 05, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
Rca parental lock. Model 20f510td
Hello
DVD door will not open and eject DVD. It says it's opening on the screen but it does not open. DVD is stuck in there
Hello
Either its loading belt in the DVD mechanism, or its loading motor has damaged. It is common that the loading belt will get loos of break. Loading belt is a small belt fasted between loadin motor to loading gear mechanism. Replace the same first. You have to open your TV and pull out the DVD mechanism outside for repair. If replacement of loading belt doesn't help, loading motror is faulty, and should be replaced. OK.
Apr 24, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
My tv keeps turning off and on by its self, is thre any way to stop this?
Sometimes the button will be stuck midway on the tv or the remote. It may also be a short.
Oct 06, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
My remote control for my rca combo 20f510td is not ejecting my dvd from the t.v. .... also actually none of the dvd buttons are doing much of anything when I press them, i.e. the play, pause, eject,...
For remote control concerns. You can try to reset your remote control but be shure before you reset your remote your tv should be unplugged from the power outlet. So here are the 4 steps to reset your remote:
1. remove the batteries,
2. press and hold the number 1 button of the remote control, thus draining all the remaining electricity.
3. put the batteries back in.
4. plug the tv on the power outlet then turn the tv on and try the remote control.
Now if these steps do not work check the warranty of the tv and have your remote be replaced if it's under warranty and if not you can try to purchase a universal remote control that supports RCA tv's.
Sep 09, 2010 | RCA 20F510TD 20 in. TV/DVD Combo
Problems getting a RCA universal remote to work for Prima tv/dvd
after you press the code search button you have to press the dvd button then enter the code
is the remote the rca systrem link?
Feb 01, 2009 | RCA 20F510TD 20 in. TV/DVD Combo
20F510TD RCA
20f510td rca cant get past the pass word input....
Oct 13, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
RCA Model # 20F510TD TV/DVD
What makes you think the picture tube is bad? What exactly are the symptoms you see? The RCA 20 inch picture tube is a good quality long lasting tube and I doubt I have ever seen a bad one.
Jul 03, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
Bush DVD142RC 14 in. TV/DVD Combo Logo
186 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
