Question about Refrigerators
Unit thermostate sticks? - Refrigerators
  • oegreiner Sep 03, 2010
    Temp control sticks. Have to hit to stop.
  • 262 Answers
You will need to replace the thrmostat if it sticks.
Posted on Sep 03, 2010
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
  • D. Floyd Kolb
    D. Floyd Kolb Sep 03, 2010
    If your banging it makes it stop then that is the first thing I would change...
    Here is a tip that will help you with the online buying...
    How to Buy Appliance Parts Online
    heatman101
Freezer gets cold but dont freeze the food
its not cold enough, it may be low on freon, if its a chest freezer it may not be economicle to repair it. or the thermostate may be set to high... to tell the difference, if the unit cycles the compressor on and off at least every few hours (or more) then its the thermostate, if the unit runs continualy then its freon
Feb 02, 2013 | Freezers
Thermostat sticking titan n180
The thermostat is there to protect the water heater. I don't think it can overheat and make the breaker trip. If you tried to reset the unit and it's still not working, you should send your Titan N180 back to the manufacturer to be repaired. The 10 year warranty if against leaks. You have 1 warranty in your Titan components.
Apr 01, 2012 | TitanNet TITANTANKLESS. COM PRESENTS THE...
When I turn the copier on: Error code E000 appears and it turns off automatically. What's wrong?
e000 means the machine not sensing the heat by his thermistor within a presetted period in "FIXING UNIT"
the main reasons are
check every connector of fixing unit.
check heaters lamp in upper heat roller in fixing unit.
check thermostate and clean/replace thermister.
if lamps,connections and thermistor and thermostate are ok then power control pcb may be faulty
Jan 06, 2011 | Canon NP 6551 Black and White Copier
I replaced the thermostate on unit and now it will not run. I replaced the old thermostate and unit will not come on. it was working before so it must be something I did in the wiring.
Hello IDHILLIS I hope you were carefull to label/remeber the colors to termnials.Check that you installed a jumper wire between RH/RC termnials.Try that.Give me the wire colors & termnials as it is now if that is done already.
Aug 20, 2010 | Goodman CKL24AR24 Air Conditioner
13500 dometic ac for rv with anilog thermostat
My Unit is only about 5 years old; but it's working great now. I spoke to a man at an RV service department, he suggest replacing the thermostate and Jay box, which is the box inside my roof unit, accessable when I remove the filter. When I replaced the thermostate nothing changed, but the Jay box did the trick. The Jay Box came with a new thermostate anyway, and cost around $80. Good Luck
Feb 18, 2009 | Dometic Rooftop RV Air Conditioner
2005 dodge ram 1500 4x4 over heating and no heat in the cab
change your thermostate. it's stuck closed.
by one of thos new one's that if it sticks it will stick open instead of closed. good-luck, ray
Jan 16, 2009 | 2005 Dodge Ram 1500
GE Microwave
thermostate sensar fit on cooling coil.near selector switch
in split a/c thermostate fit in indoor unit.c the thermostate open indoor unit.
Mar 13, 2008 | Heating & Cooling
Sc545 code apear after replasing heater unit it is stell what is the sd codes
The middle thermoster in the fuzing unit (heater )is out of position or something is obstructing it from reading the temperature on the hot roller , or the thermoster is faulty
Nov 06, 2007 | Ricoh Aficio 2027 All-In-One Laser Printer
Service problem
This code is a fuzing unit code , one of your thermosters are busted or dirty so it is not picking up the heat correctly , ill sugest you take out the fuzing unit and clean both thermosters and try again , but you need to reset the code after cleaning the thermosters by pressing :yellow c 107 and hold down orange c until it shows copy sp mode press 1 # then turn the power switch on and of hope this helps
Nov 05, 2007 | Ricoh Aficio 2020 All-In-One Laser Printer
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
