Question about Fuji FinePix S2000hd Digital Camera
I have a fujifilm s1000 fd and i used a card reader to download the pictures from my camera(i specify that i have a SanDisk memory card), because i can't download them using the cable ,it just downloads some pictures and after that an error appears and everything blocks. i have gone used to that but recently i tried to put some pictures and movies that i taken with the camera back on the memory card using the card reader but the camera just doesn't reads them. Can i solve this problem? If not can i solve the problem with the cable error?
    Brigadier General:
  • 11,967 Answers
Your computer and your camera use different operating systems. If you try to put pics and videos on a card using the computer and then try to play it in your camera, you take the risk of corrupting the card and the camera. Also, if each time you remove the card reader from the computer, you don't use the "safely remove hardware" function, you corrupt the card further. These are probably the reasons you're having problems.
Posted on Sep 03, 2010
Fujifilm finepix s2900
If the pictures are in the camera's internal memory, first copy them to the memory card using the Copy command in the Playback menu. See page 89 of the manual: http://www.fujifilm.com/support/digital_cameras/manuals/pdf/index/s/finepix_s2800hd_manual_01.pdf
To download the pictures from the memory card to your computer, take the memory card out of your camera and put it into a card reader attached or built-in to your computer. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
Oct 21, 2013 | FUJIFILM Cameras
Copy photo from FUJIFILM A170 SD card
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
If you're asking how to copy the pictures from the card to somewhere else, please reply to this post and specify to where you'd like to copy the pictures.
Sep 11, 2012 | FUJIFILM A170 Digital Camera
After deleted Pictures n Videos by mistake, how to recover PICTURES n Video in FUJIFILM FINEPIX F300EXR?
First of all, do not save any new file to camera's memory card.
Take out memory card, and connect it to computer using a card reader. You should see memory card shown as a drive letter (like H:) in Windows Explorer.
Download this camera photo and video recovery software
http://www.asoftech.com/adr/
Install and open the data recovery software, select the memory card, and click 'Next' button.
Jul 17, 2012 | FUJIFILM FinePix F300EXR Digital Camera
I have a Fujifilm finepix digital S1000 fd camera. When I put in my batteries today, it said on the screen 'protected card'. How do I get this off so I can take photographs?
Take the memory card out of the camera and look at it. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 09, 2010 | Fuji Cameras
I can't download my photos on my finepix s1000. I
Try NOT connecting your camera to your computer.
Nov 01, 2009 | Fuji FinePix S1000FD Digital Camera
I have a finepix s5500 camera but the softwear is xp and i need a vista version, is it possible.
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Oct 17, 2009 | Fuji Finepix Z20fd Digital Camera
Camera freezes after taking picture
I had this problem with my s1000 Fujifilm, but solved it by changing the standard SD card for a SDHC class 4 card. It no longer freezes when a flash is used! I've tried a 4Gb and a 16 GB SDHC class 4 card and both are fine.
Bazz
Nov 25, 2008 | Fuji FinePix S1000FD Digital Camera
How to install Fuji Finepix 2650 in Windows VISTA environment?
Accessories
Nov 11, 2008 | Cameras
Problem with uploading photos from fujifilm finepix s1000
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 13, 2008 | Cameras
Batteries Died While Downloading
yes you can still retrieve your pictures,by using a card reader.it is a device that can use to read any kinds of memory card.
Mar 18, 2008 | Cameras
Fuji FinePix S2000hd Digital Camera Logo
80 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
