Question about Logitech QuickCam Chat Personal Web Camera
I cant get audio
When i run the wizard, it sayd no sound was picked up and ends it, iv repluged adn redownloaded several times and still no luck, what am i doing wrong?
  • Lucky
    Lucky May 11, 2010
    Check the settings yo can do that by
    Determine whether it is a hardware problem by testing the microphone in Sound Recorder.
    Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
    Click the Record button and speak into the microphone of the camera.
    You should see the green line move, indicating the application is picking up sound.
    Click the Stop button.
    Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    Click "Edit," then "Audio Properties."
    Make sure Logitech is listed as the Preferred device for "Sound recording."
    We also recommend using the camera on another USB enabled system.
    If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
    Or
    You can download the manual from here
    http://logitech-en-amr.custhelp.com/cgi-...
    Setting up sound instructions :
    http://logitech-en-amr.custhelp.com/cgi-...*&p_li=&p_topview=1
    Or
    You can also check this :
    Last, make sure that you are using the latest drivers.
    You can upodate them from here.
    http://www.logitech.com/index.cfm/492/&a...
    Hope this helps.
    Good Luck.
    Live, Love, Laugh.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Or
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/fattach_get.php?p_sid=NvvPcy3j&p_li=&p_accessibility=&p_redirect=&p_tbl=9&p_id=2929&p_created=1126110111&p_olh=0
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3172&p_created=1132615129&p_sid=NvvPcy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTEsMTEmcF9wcm9kcz04NDQsNSw4NTgmcF9jYXRzPSZwX3B2PTMuODU4JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bm8gYXVkaW8*&p_li=&p_topview=1
Or
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=3189&p_created=1133485072&p_sid=NvvPcy3j&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTEsMTEmcF9wcm9kcz04NDQsNSw4NTgmcF9jYXRzPSZwX3B2PTMuODU4JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9bm8gYXVkaW8*&p_li=&p_topview=1
http://www.logitech.com/index.cfm/492/&cl=us,en?prodcrid=492
Hope this helps.
Good Luck.
Live, Love, Laugh.
Posted on May 12, 2008
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
I cannot chat voice with my sister but able to chat with another person. what could be the problem
This is usually a problem with bandwidth on her end or with improper microphone or sound card installation on her end. Sounds like your end is okay if you can chat with another person. You can have her click the Help menu in Messenger and select Audio Setup Wizard. Run through the setup wizard and be sure that all of her audio devices are set up correctly. If this doesn't cure the problem, then bandwidth is most likely the culprit.
Good Luck
Gill
Sep 24, 2010 | Yahoo Messenger
Toshiba Satellite A205-S4607 Audio Driver on Windows 7 x86
Instructions to Fix Windows Error Code 0x00000017:
Apr 12, 2017 | Toshiba Satellite A205-S4607 Notebook PC
Im sorry to tell you this mate but the driver needed is not supported by windows 7 its just one of those glitches that new OS's have give it time the driver will come out
Mar 17, 2010 | Toshiba Satellite A205-S4607 Notebook PC
Why can't i get digital audio stations on my Akai lct374zad TV. I've scanned several times and it only picks up the digital video stations.
i dont know but tv stations comes with sounds and video syncronize.then you will need a digital radio to get digital sounds from radio stations.good luck.
Mar 01, 2010 | Televison & Video
Getting mic setup thru cubase le 4
Make sure phantom power is enabled on the Tascam audio interface and you must enable the input in cubase that corresponds with the interface input on the track you are trying to record to.
Sep 28, 2009 | Tascam US-144 Sound Card
Audio drivers crash pc , no sound
Hi
Just install UAA hotfix and enjoy sound
Harry
Jul 14, 2009 | MSI M670 Notebook
F28
F20 usually means that the drain is plugged. It could just be twisted or compressed as well.You can check the washer drain by pulling it out from the wall and unclamping the drain hose (black about 2"diameter) and check for a plug. You can also sometimes pull it out of the standpipe or wall drain if you cant clear from the washer end. Be sure to turn off the washer and unplug it before you do htis, and have some old towels handy and a container available. If the washer drain is not plugged, it could be that your household drains are running slowly. Check your sinks, toilets, etc and in particular run a lot of water through your disposal if you have one and run it.
After you have cleaned the washer drain adn reattached the hose, let it sit unplugged for several minutes (Don;t get the plug wet!) Then replug it and turn it on and see if the code has disappeared. If it has not you will need to go to the following site
http://www.whirlpool.com/custserv/index.jsp
And look for the appropriate sevice for your machine.
Thank you for using Fix YA and good luck to you.
Aug 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
6 channel sound card driver for Asus A7n266VM
well, the first step is to make sure the sound drivers are installed properly. Does the device show up properly in the Device Manager? Does it show up in the Audio/Sounds configuration item in the Control Panel? If so, then:
Does any sound work, and it's just the extra channels that do not operate? If that is the case, you probably just need to run the configuration wizard. It sometimes sits in the tray, but almost always is available in the Control Panel. Once you run it you can pick what kind of speakers you have to control the various sound outputs properly for your setup.
Nov 24, 2007 | ASUS NVIDIA nForce Chipset A7N266-VM...
Logitech QuickCam Chat Personal Web Camera Logo
37 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
