Question about MSI MS-6398E Motherboard
1short beep 2short beeps 1short beep - MSI MS-6398E Motherboard
    President:
  • 2,666 Answers
Looks like you need a new MoBo. See Here
Posted on Sep 03, 2010
Laptop beeps 32 times on boot up
http://www.bioscentral.com/beepcodes/awardbeep.htm
maybe will help ,but try to lessen how are grouped (the beeps) thing like 1short +3 long +2short.
like if there are problems with the ram will be 3 normal beeps .
try to group the 32 beeps .
Jun 22, 2013 | HP Pavilion Dv3-1075us Notebook
As i turn on my pc, i hear 1long and 2short beep..and the light of the monitor power is blinking..what could be the problem? Hope that you can help me..TNX
The beep code you are getting Indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information. Plan English - you have a bad video card or port. If your video output is on a PCI card, replace the card. If it's on the board, you will need to replace your motherboard.
Good Luck
C2Solutions
Jan 19, 2011 | Computers & Internet
Aspire 5100 beep 1long 2short power indicator on but no screen
first check the VGA able.. if VGA not work supply not comes to monitor
Oct 14, 2010 | Computers & Internet
2long 2short 2short beeps on mother board
You really need to go to the BIOS manufacturer's website to ensure the beep codes are the same but here is a link to a site that has some of the common codes with different BIOS manufacturers. To determine which BIOS you are running, when the computer boots up, it should be at the bottom of the screen as it initializes each device. It looks like a black screen with a bunch of lines popping up with the status of each device. The Bios will be down at the bottom left during this process. IF you have a splash screen instead you will need to interupt the bios boot process, either by hitting the DELETE button, or F1 or F2, depending on the manufacturer. Hope this helps. If not post back with the computer manufacturerer and model number and I will try and determine the step by step instructions to assist you.
http://www.5starsupport.com/info/beep_codes.htm
Aug 03, 2010 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Asus cuv4x-c problems, all capacitors is ok, im getting series of beeps (continuous beeps)
A lot more than just capacitors could be the problem. First things first, if you have a tester, test the power supply. Next is most likely memory problem. Remove the memory piece/pieces clean the contact and memory slots (blow-out with air). Reseat the memory in proper slots. While you are in there, also check that all components are seated. Re-seating the memory should correct the problem. If not, use some different memory sticks to check again. Note: Motherboards are cheap, If your power supply is OK and you are sure the memory sticks are OK, just replace the motherboard.
May 24, 2010 | ASUS VIA Apollo Pro133A Chipset CUV4X-C...
Abit av8 bios post codes 8.3 - 8.6 - 9.c What is failing on boot ? I get one long beep followed by 4 short beeps. I have swapped video cards and reflashed the bios with no help. If I reboot 2 or 3...
I still did not find beep code that match your problem..
Anyways here are the common beep codes for your motherboard.. it might help you too.
1. No beep - no reaction, the mother board is dead, power supply problem, processor and or ram problem.
2. 1beep - board is working fine.
3. One long beep then it shuts down - cpu problem, your processor is not working or missing.
4. 1short beep - system boots normally
5. 2short beeps - CMOS setting error.
6. 1long 1short beep - dram error
7. 1long 2 short beep - video card or monitor not connected
8. 1long 3 short beep - keyboard error.
9. 1long 9short beep - ROM error
10. Long beep - memory card is missing or not connected
11. Short beep - power supply error
12 Four beeps - there is no fan detected on Fan1 or Fan2 header. make sure to attach or reset CMOS bios to factory setting.
Hope this gave you an idea of your problem..
Much appreciated if you rate this help..thanks..
May 23, 2010 | Abit AV8-3rd Eye Motherboard
Video card problem - laptop screen blacks out.
it may be possible tht u need to upgrade ur video card memory
Jun 19, 2009 | Acer Aspire 5000 Notebook
No display on screen only 1 long beep then 2short beeps
This is a memory error. First remove all your memory then put it back in again. If the error persists and you have more than one memory module, remove one at a time and see if it will boot. If you only have on module, then that module will have to be replaced.
Jun 14, 2009 | HP Pavilion dv2000t Notebook
Motherboard gave 3 beeps
Hi, it sounds like your Ram was not seated fully the first time and has damaged the contacts. Get another stick of RAM and install that making sure it is fully seated and then try again Regards mistyman
Aug 18, 2007 | EliteGroup P4M800-M7 Motherboard
MSI MS-6398E Motherboard Logo
46 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
