Question about Metrologic Instruments MS7120 ORBIT Barcode Scanner
What causes my Metrologic MS 7120 to not scan Code 39 font?
3 Suggested Answers
mevanforu
SOURCE: MY METROLOGIC BAR CODE
What Is The Communication Method You used, usb or Kbw,
Posted on Sep 25, 2008
Hyarion
  • 74 Answers
SOURCE: to check warranty of product metrologic barcode reader ms 1690 or
Metrologic doesn't have an online warranty checking facility, but you can contact them by phone and request them to check it.
You will need to have as much of the following information as possible ready for when you speak to them:
Customer ID Product Type Serial Number / Date Code / Dated Proof of Purchase.
Ideally have the barcode scanner with you while on the phone so that if they ask you to check for specific serial numbers or codes you have it readily available.
They have multiple contact centers, as I'm not sure what location you are in, please take a look at their website link below to get the phone number for your area.
Most common number: +44(0) 1 925 240055 - United Kingdom.
http://www.honeywellaidc.com/Site.aspx/eu/en/contact/locations/
Posted on Apr 07, 2010
Ms 7120 barcode scanner does not scan some barcodes
i have 4 Digit Barcode From my Software i Printed it not reading the Font Name is (C39Hrp24DhTt)
Sep 30, 2011 | Microsoft Metrologic MS7120 ORBIT Barcode...
We can not get the scanner to reset to the factory defaults.
I am not sure if you try this yet,
If you scan the bar code located on page 14 from the manual (link below) it should reset the scanner back to factory default
http://www.barcode-uk.com/images/downloads/Metrologic%20MS1690%20Scanner%20CernInst.pdf
I hope this helps and best of luck!!
RM
Mar 10, 2011 | Metrologic Instruments Metrologic MS1690...
Barcode font problem
Try going to the manual and scanning the setup code for accepting a the I2of5 code.
May 21, 2010 | Metrologic Instruments 9520 Voyager
EVERYTIME I SCAN SOMETHING, I HAVE CAPS LOCK ON, WHICH IS WHAT I WANT, AND IT SCANS LOWER CASE. HOW DO I FIX THAT?
Do not use CAPS LOCK while scanning - the CAPS LOCK function works backwards when scanning. If you want UPPERCASE then do not use the CAPS LOCK on the keyboard.
Mar 25, 2010 | Metrologic Instruments Metrologic MS 951...
Need metrologic MS 951 driver
This scanner does not need any driver. If you connect via keyboard, the connection is transparent. If connecting via RS232, you need a program to receive data in the com port and send the keyboard buffer.
Roberto Martinez
Sep 24, 2009 | Metrologic Instruments Metrologic MS 951...
Metrologic barcode scanner - laser is a dot not a line
This would be a fault with the scan engine. The dot is created when the mirror inside of the scan engine is not oscillating. The best solution is to have the device repaired, hopefully your scanner is still under warranty, or to purchase a replacement. /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 90.0pt 72.0pt 90.0pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Mar 09, 2009 | Microsoft Metrologic MS9520 Voyager...
Aug 06, 2008 | Metrologic Instruments Metrologic Barcode...
SCANER BEEPING
hello,
I have a same issue with my MS-7120, how ever mine is in worse stage, when i power up, it beeps and u can see green/red light blinks on top, and it tries to spin the inner motor + tries to turn inner light on, but after several seconds it goes dead. how ever red/green light blinks on top.
i contact the company which i purchased from, he told me these scanner has life expectation of approx 3 years, after 3 yrs they die.
i was told cause is from heavy/light voltage transfer from outlet.
and they have to be repaired by orbit support.
i am afraid to tell your, sounds like urs is ready to die. just beware !!
i hope this information helps you.
Jun 23, 2007 | Metrologic Instruments MS7120 ORBIT...
Metrologic Instruments MS7120 ORBIT Barcode Scanner Logo
152 people viewed this question
Top Metrologic Instruments Computers & Internet Experts
Gareth Cockram
Gareth Cockram
xak_tay98
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
