Question about Jandy Laars Lite2 Ld 400,000 Btu Heater
Gas man is checking my pool heater. When starting up the burner lights then goes out. What could be causing this?
  • Jandy Master
  • 43,501 Answers
Often that is because of a bad or dirty flame sensor...The flame passes a current through the flame and theat proves that there is flame... if the flame is not hitting the sensor or it is dirty it will not pass the current through... also check that the burner ground is not corroded or loose...
These can be a bugger to fix...
and sometimes it turns out to be a bad sensor or a bad ignition module...
heatman101
Posted on Sep 03, 2010
Pool Heater. Hayward H100ID Starts fine and heats for about 5 minutes. Then heat stops. You can feel the blower its just cold air.
It sounds like your pool heater is not firing. I would check several things: the burner might be blocked and clogged, the gas valve might need to be replaced, the direct spark module might be malfunctioning, or the combustion blower might be cleaned. One of these is probably the issue. A service man can repair all of these problems.
Aug 08, 2010 | Hayward 100kbtu Pool Or Spa Propane Gas...
My pool heater wont start the pilot light is on the red light is blinking and the fuel tank is full the temp. Is on high .the burners came on for asecond and then shut off?????what should i try to do now??
With these pool heaters, there are a couple things that you can check yourself before you call a pro for this problem. Try cycling the ignition sequence until all air is out of the gas line. Also, check your gas valve. If it is manfunctioning, it will need to be replaced.
Jul 12, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Have pilot but burner will not start. Gas line is
There is an internal pressure switch for this unit that must sense water pressure before the gas valve solenoid is energized so that burner will light. If the air line to the pressure switch is leaking or has failed or is blocked it will not light at all. Additionally if you have had mice or smaller rats get into the unit, check the wiring to the pressure switch for any signs of damage. They can cause havoc! (Personal experience)
If you need further assistance please include your exact model number of your pool heater in your response.
Thanks for using FixYa.
Kelly
Jun 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
How do you clean the orfices of spider webs?
you have to remove the burner assembly to properly clean the unit. remove the front panel there are 2 screws on the burner tray remove these and disconect the small pilot supply tube and slide the tray out to clean. use a wire brush lightly and an air compressor to cleat out the burners and the orfice.
Aug 01, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
LARS LITE #LLG175N BURNER WON'T STAY LIT.
Make sure your pool filter is clean. Low water flow through the heater will be detected by water pressure switch
Jun 19, 2009 | Teledyne Laars Teledyne_ Laars Lite2...
Heater won't stay lit
On your main gas manifold you have orfaces that screw into it at each burner. Remove these and see if their are small spider webs in them. They will look like little lint balls. They can keep your main burner from getting gas and in turn keep the heater from sensing flame. The pilot lights and the heater starts but no flame at the main will shut it rite down. See if this helps.
May 05, 2009 | Hayward H Series Millivolt 250,000 Btu...
Jandy Laars Lite2 Ld 400,000 Btu Heater Logo
306 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
