Question about FMI CPU Sensor Alarm Temperature Monitoring Device
What is a safe temperature range for my E8400 core2duo
Hi, i have my core 2 E8400 wolfdale overclocked from 3.0 x2 to 3.6ghz x2, and it goes up around 70 celcius, i was wondering this if this is something i should be concerned about, or if it is normal for these chips to run this hot.. thanks
70 degrees is a tad high, I'd suggest buying an aftermarket heatsink or re-seating your current one.
Posted on May 26, 2008
How to enable virtualization for Intel core 2 duo e8400?
the virtualisation capability is an option in the bios; that is where it can be anabled. To get into bios begin the boot up process and hit the delete button continuously. On some boards it is the F2 button but it should be the delete button on your board.
Remember to save the option on exiting.
Feb 19, 2015 | Intel Core 2 Duo E8400 Processor...
I am not able to open my ymail.com account on my pc
Are you running firefox or chrome? install one of those, make sure flash/java etc are up to date.
Sep 29, 2012 | Intel Core 2 Duo E8400 Processor...
HI, i have the gigabyte MB GA-945P-S3- and i saw in GIGABYTE web site that i can go with C2D E8400 but with overclocking and saw awhile ago that there are another problem with the CPU MP in the bios of it...
Only the Gigabyte GA-945P-S3 revision 3.3 does allow C2D E8400 or C2D E7500.
However the C2D E8400 only by overclocking, which certainly is not recommended.
So the Gigabyte GA-945P-S3 mainboard revision 3.3, should work with the C2D E7500
with BIOS version FFd and FSB setting at 1066 MHz.
Sep 04, 2011 | Gigabyte GA-945P-S3 Motherboard
What is safe temp. For core2duo
Here are the list of safe temperature for the Core 2 duo processor please check below what type of processor do you have. But base on my experience all core 2 duo processor should not go above around this numbers provided below...
X6800 - 60.4c
E6700 - 60.1c
E6600 - 60.1c
E6400 - 61.4c
E6300 - 61.4c
E4300 - 61.4c
Hope this will help you . God Bless!
Apr 19, 2011 | Sony Computers & Internet
Bios update for t5226... intel update will not work.. some people say it is locked by emachines. i am trying to put an e8400 in it, but i don't think that the processor is supported by the older bios...
It isn't the fact of the BIOS, it's the motherboard chipset.
The eMachines T5226 uses an Intel 945G.
This chipset only supports processors with up to a 1066MHz FSB.
Supporting Data:
1) eMachines T5226 specifications;
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T5226
2) List of Intel Chipsets, and more specifically the Pentium 4/Pentium D/Pentium EE chipsets,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4.2FPentium_D.2FPentium_EE_Chipsets
The Intel 945G is the 12th one down, or last in the list.
Looking across to the right, you can see the Intel processors supported, and the maximum FSB support.
(533/800/1066)
The motherboard's BIOS also won't let you overclock the FSB.
The Intel Core 2 8400 has a 1330MHz FSB,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Wolfdale.22_.2845_nm.29
The Intel 945G also won't support Intel processors with the Wolfdale Core.
Feb 18, 2010 | E-Machines T5226 PC Desktop
MSI P6N V2 motherboard doesnt work with Core2Duo E8400
ur motherboard goes dead now only one solution have that u must change ur board . coz by overclocking ur motherboard vg chip gone burn and no one can change that chip .thanx enjoy good luck plz vote for my comments
Apr 20, 2009 | Computers & Internet
Hello i just wanted to ask you guys something: i have a e8400 stock @ 3ghz and when i play games like crysis it seas that it's heated up to 45-48 degrees celsius and when i'm not playing any games i have...
the better the cooling you can add to the processor the cooler and better your cpu will be. the 140mm fan is a case fan, yes?
you will need to upgrade your cpu fan and heatsink.
CPUs on 45nm core are overall cooler than their predecessors on Core micro-architecture. However, the temperature different under 100% workload makes only 4-5 degrees. The thing is that Wolfdale processor core is smaller and features higher transistor density within a semiconductor die, which makes it a little harder for the heat flow to dissipate properly. That is why Wolfdale and Conroe heat up almost identically in idle mode. As for the relatively low temperature of AMD Athlon 64 X2 6400+, with twice as high TDP as that of Core 2 Duo actually, it can be explained by the not very best location of the on-die thermal sensor that is situated quite far from the hottest spots of the processor’s semiconductor die.
Mar 01, 2009 | FMI CPU Sensor Alarm Temperature...
AMD or Intel Processor for desktop gaming and animation purpose
when it comes to new processors i would definatly suggest any intel from the core 2 series. AMD is having problems with overheating and has all but abandoned thier quest for quad core glory.
Jan 25, 2009 | Intel Computers & Internet
FMI CPU Sensor Alarm Temperature Monitoring Device Logo
1,597 people viewed this question
Top FMI Computers & Internet Experts
David Payne
David Payne
Are you a FMI Computer and Internet Expert? Answer questions, earn points and help others
