Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Hi . we have a kenmore model 106.74259400. the freezer gets frost in it and it continually gets worse. and the fridge is not very cold nor is the freezer. why is thi s happening?
  • 90 Answers
SOURCE: Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Posted on Jan 05, 2008
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: My fridge makes loud popping noises
buy a new one that always woks
Posted on Mar 28, 2008
22yooper
  • 828 Answers
SOURCE: kenmore sideby side fridge
You have a defrost system problem. Defrost is controlled by a timer which energizes the heater circuit. The heater circuit has a radiant or cal rod type heater which melts the frost from the coil. When the coil reaches a temperature where all ice would be gone a termination switch opens and shuts of the heater. The timer will continue to run until defrost time expires (18-22 minutes).
If you can locate the timer there is a clutch head screw to advance the timer to the defrost position. Turn the screw clockwise SLOWLY until you hear one audible click. The heaters should come on and defrost take place. If the unit restarts after the 18-22 minute period the timer is good, if it does not restart advance the screw to a second audible click and it will restart.
If you had to turn the timer the to second click to get it started cooling replace the timer.
If the unit restarted after the 18-22 minutes and defrost did not happen your problem is in the heater circuit. This would be an open heater or bad defrost terminator switch. To access the heater and defrost terminator the back panel in the freezer section must be removed. With an Ohm meter you can check the heater to see if it is good.
Posted on Jul 02, 2008
  • 24 Answers
SOURCE: freezer cold but not fridge
too much ice bulid up will stop enough cold air being blown into the fridge.Try turning it off letting all ice melt then turn it back on again and set thermostat at a lower temp.There may be ice you can't see.
Posted on Oct 08, 2008
Freezers high tempeture light is on and freezer is not getting cold
Door left open usually starts a defrost failure, the evaporator gets blocked with frost and the fan motor can't circulate cold air into the fridge section- while the freezer fan is running, put your hand in front of the slots where the cold air should be blowing in the fridge section- if you don't feel air flow, you have a blockage. Help Me Find My Model Number RepairClinic com
Aug 30, 2016 | Kenmore Refrigerators
Kenmore refrigerator Model 253-68232800 will not keep food cold in fridge and frost build up in freezer.
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
http://www.espares.co.uk/advice/fridges-and-freezers/a/2
Sep 14, 2011 | Kenmore 64722 Top Freezer Refrigerator
Kenmore elite frost free is frosting over
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
12 yr old kenmore top freezer. Freezer get real cold but does not freeze. Fridge part does not get very cold. I cleaned all the dust from coils, fan runs and all the seetings are good.
Top of Form
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Inside of freezer is frosting in the inside. fridge is not keeping items cold.
heatman101
Jul 31, 2011 | Kenmore Top Freezer Refrigerator
We have a Kenmore Fridge. The freezer will not freeze anymore but the fridge works fine. We did unplug the fridge and let it sit for 24 hours to see if that would help the freezer to work again. it...
IT'S FUNNY THAT THE FRIDGE SIDE IS WORKING AND THE FREEZER ISN'T,ALL THE MACHINE DOES IS GET COLD IN THE FREEZER AND THE EVAP FAN BLOWS COLD AIR FROM THE FREEZER TO THE FRIGE SECTION.IF THE FRIDGE IS COLD AND THE FREEZER IS RUNNING WARMER THAN IT SHOULD YOU COULD HAVE A SEALED SYSTEM PROBLEM,SOMETHING WGONG WITH THE COMPRESSOR OR A LEAK IN THE SYSTEM.THE GAS WILL CONTINUE TO LEAK AND THEN BOTH SIDES WILL GET WARMER AND WARMER.YOU CAN REMOVE THE INSIDE FREEZER WALL,LOOK AT THE EVAP COIL AND CHECK THE FROST PATTERN ON IT,WHEN IT'S RUNNING CORRECTLY THE WHOLE COIL WILL FROST UP BUT IN YOUR CASE YOU'LL MOST LIKELY FIND THE COIL PARSIALLY FROSTED OR JUST THE TOP OF THE COIL WILL HAVE ICE ON IT,THAT MEANS NEW FRIDGE TIME,IT WOULD BE TO MUCH MONEY TO REPAIR IT.LET ME KNOW WHAT YOU FIND WHEN YOU LOOK AT THE COIL AND WE CAN GO FROM THERE
Nov 23, 2010 | Kenmore 14.8 cu. ft. Top Freezer...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
175 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
