Question about Homelite Mighty Lite Lawn Trimmer
The fuel line on the homelite brushcutter mightly light have degraded and split, can I change them and if yes, how, or do I have to buy a new petrol tank?
    President:
  • Homelite Master
  • 1,545 Answers
Yes, its a do-it-yourself deal. They have fuel line kits at Home Depot and at the small engine shops. They use what they call "tygon" lines now. Remove old lines. One of them should have an in-tank fuel filter on the end. You can use needle nose pliars or even twezers to reach into the tank to grab. The fuel lines themselves seal the holes in the tank. No sealant is used. Cut new lines long and angle cut an end. Start that cut end thru the hole in the fuel tank and push it in slowly until there is enough to grab. Cut filter line lone enough so that it will move around on far side of tank, then put fuel filter on its end. The other line you shove into the tank will be pulled back thru and cut to a length aboutm 1/2" or so...it should have some type of little nylon connector on its fuel tank end to hold it in the tank . Good luck. Please vote on this solution.
Posted on Sep 03, 2010
Ryobi brushcutter runs good on full tank gas but at a half a tank it starts spitting and sputtering...why
CK for split fuel lines. You can ck when fuel is low by trying to prime with bulb, if you see air bubbles in line , split line in tank.
May 03, 2014 | Cars & Trucks
Spear & Jackson 33cc Petrol Grass Strimmer SGT33N, black fuel pipe split. How to replace it?
empty the petrol,feed the black line (the fuel intake) into the tank and grab the end of it thats attached to the filter inside the tank. now you can feed a new fuel line through into the tank and reattach to the filter. hopefully this will solve your problem ive just done this but mine still wont start, either flooded or spark plug. by the way i bought mine new and the fuel line was split.
Jun 05, 2013 | Garden
My Homelite XH2XS-0254RA Trimmer gas lines have broken off inside the gas tank, can replacement parts be obtained
Hi carlfreeland...
Yes, your fuel lines can be replaced, be sure to get the right size to fit your machine.
Go to your parts supplier with the model/serial number and manufacturer of your weedeater.
Most of the time there will be two size fuel lines, the bigger one is the one the fuel filter inside your tank is connected to.
Please take time to rate me
Jul 03, 2011 | Homelite Expand - It Brushcutter...
I have recently purchased a line trimmer split shaft(hbc26sjsnb) and it will not start>Only way I can get it to fire is to dip spark plug in fuel ,but then it fires up but will not run - do I take...
This is a common problem for home owner machines rated for 50-75 hours of use. Is this Homelite "brand new" never used or is it brand new -only run a few hours? most machines will develop a problem after 30-60 days when sitting with fuel in them. This is because the 10% Ethanol in most cities leeches polymer strands out of the fuel system and combines them with the moisture of the air and oil in the fuel. This makes for a sticky white substance that blocks passage ways and sticks one way valves open. My fix is to purchase a $20 jewelry cleaner at a local tool shop and clean the carburetor (located behind the air filter) make sure your fuel lines have not been affected or damaged by the Ethanol and put the machine back together.
Using a high quality oil such as Stihl Ultra Oil can help prevent problems. You can also purchase fuel premix with no Ethanol through shops like www.arcolawn.com.
Good luck
Feb 11, 2011 | Homelite Expand - It Brushcutter...
I have a husqvarna 255r brushcutter, my son put wrong mix when petrol changed to unleaded and the 2 stroke oil, we have it 5 yrs used on 4 TIMES oooh ...but anyway told pistons gone, son and h/band not...
Unless really trashed you can simply replace the piston, and re-bore/resleeve the cylinder, that will cost much less.An competent motor bike, or lawnmower repair shop should be able to do that for you, that way you could get a "Kit" online, and simply do that.
http://www.instructables.com/id/How-to-Repair-a-Lawn-Mower-Engine./
http://www.repairfaq.org/samnew/lmfaq.htm
http://www.bbssystem.com/manuals/Small-Engine-Repair-Ebook.pdf
May 26, 2010 | Husqvarna 28cc Gas Line Trimmer
Cracked fuel line
you can get many sizes of hose at the home depot
May 16, 2010 | Homelite Mighty Lite Lawn Trimmer
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
Mar 20, 2010 | Homelite Expand - It Brushcutter...
My Homelite brushcutter wants to staret but stalls
ckeck for cracks in the fuel line sometimes they will crack and **** air, also the carb could need to be cleaned
Feb 21, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite Mighty Lite Lawn Trimmer  Logo
235 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
