Question about Hitachi 18V Lithium Ion Cordless Hammer Drill DV18DL
I need to replace the brushes in a Skil Xtra-Tool 599, and can't find my manual. Are these a generic size, and if so, what size should I order?
Skil belt sander model 448 plastic handle
Contact direct
Owner's Manuals & Parts Lists Make the most of your SKIL tools. Review owner's manuals and parts lists online by searching in the desired tool category.
If you're looking for an older model that isn't listed, call 1-877-SKIL-999 (1-877-754-5999) or email Customer Service.
For manuals and parts lists on models beginning with SPT, please visit www.SKILSAW.com
Owner Manual Parts Lists
Mar 24, 2018 | Skil Tools & Hardware - Others
I need the owners manual for skil router model 1825
Many Skil tool manuals are available from the manufacturer here: https://www.skiltools.com/Parts-And-Service/Pages/Owners-Manuals-And-Parts-Lists.aspx . Select Routers and then scroll down to find the 1825. The direct link to the manual is currently http://mdm.boschwebservices.com/files/r00576v-1%20r19291v5.pdf .
I hope this helps.
I
Apr 07, 2016 | Skil Saws
How do I install new brushes on 15 amp motor for 3400 skil table saw?
http://www.ereplacementparts.com/skil-3400-f01234000a-table-saw-parts-c-130_164_7498.html
Here is the breakdown - I believe the brush tubes just friction fit with the wire connected by a spade terminal.
Jan 14, 2015 | Skil Saws
I need the outer flange/blade clamp for my Skil model 77 type 15
This sounds like a worm drive. Try going to this web site to order your part.
http://www.ereplacementparts.com/skil-shd77-f012sd7700-worm-drive-skilsaw-parts-c-130_160_7479.html
This is the part for the blade clamp washer $5
Blade Clamp Washer
This is the flanged plain washer $4
Blade Clamp Washer
and retaining ring $4
Retaining Ring 2610341359 for Power Tool eReplacement Parts
Dec 03, 2014 | Skil Saws
Missing skil jigsaw set screw
This will be a generic METRIC screw, take it to a fastener supplier and show them the hole, they can try out fit of a few METRIC screws to find the right size. Buy the screw/bolt that fits and hacksaw the head off it to make a set screw.
Nov 25, 2013 | Skil Standard Duty Jigsaw Model 497 1/3 Hp
Skil 3316 Compound Mitre Saw 10"
I suspect that the brushes have fallen out between the end bearing and the armature bars.. Try removing the brushes and see what happens.
May 18, 2013 | Skil 10-in 15-Amp Compound Miter Saw...
I have a Skil Belt Sander 405. I bought at a sale. How old is this sander? How can I get a belt for this sander?
http://cgi.ebay.com/4-x-21-3-4-sanding-belts-36-grit-qty-10-/310329120043?pt=Sanders_Sandblasters&hash=item48410e952b
this is the type of belt it uses (size rather) 4"x21 3/4" you can find them on ebay.
http://www.skiltools.com/en/ here is the official skil website. they can probably email you an owner's manual if you wish
hope this helps out. this one is vintage from what i understand
thanks,
mike w
Jul 07, 2011 | Skil Tools & Hardware - Others
I have a 10'mastercraft table saw with the carbon brush gone,and cannot not find one no place,cannot find a scrap one anywhere could you help
Try this link. If that doesn't work, see if the motor has a manufacturer or model number on it, or if the old brushes have a number stamped on them and use that to search online. Go to google and search "motor brushes" Good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 30, 2011 | Saws
I have a aeg ph38 electric 800 watt chipper hammer, i need to find carbon brushes and the carbon brush holders for the tool.
RE AEG PH 38 Brushes go to local hardware storeinthe miscelleanous everything aisle and look or a SKIL brush set exact size match $4.50 US cost I fixed mine today. Brush holders another issue
Apr 25, 2011 | Garden
I need an operator's manual for a skil router table ra 750
you need to contact skil directly, i know that they are sending manuals on requests, just e-mail them or speak with sales rep on this site:
http://www.skiltools.com/en/CustomerService/PartsListsOwnerManuals/
generic fixed base routers manuals on line are available here:
http://powertool.manualsonline.com/manuals/mfg/skil/1810_1815_1820_1825_1.html
if you find my advice helpful, please do not hesitate to leave your comment and vote for me, thanx!
Jul 31, 2010 | Skil Power Tools Routers Fixed Base
Hitachi 18V Lithium Ion Cordless Hammer Drill DV18DL Logo
182 people viewed this question
Top Hitachi Drills Experts
John Trevino
Are you a Hitachi Drill Expert? Answer questions, earn points and help others
