Question about Eton FR300 AM/FM/Weather/TV Radio
The weather band on my Eton FR300 no longer works. When I turn it on, I first get a couple of words from the current radio report then the radio goes completely silent. All other bands and components work fine...seems to be only a weather band circuit problem. Thanks in advance for any help.
  • dolcevita09 Sep 04, 2010
    I would like a schematic for this radio. With that, and electronics buff friend may be able to identify and replace the defective component. Thank you.
  • dolcevita09 Sep 05, 2010
    Thank you. Can you provide a schematic showing the frequency diode that should be replaced?
  • 3,247 Answers
I believe the weather band transmission is on the VHF band which is also used for VHF TV channel transmission. So if you are close to an area with strong TV signals then you may be having this problem.
Maybe you need to get away from a TV transmitter in your area and try if there is any difference.
The weathe channel frequencies are
Channel 1 162.400 MHz
Channel 2 162.425 MHz
Channel 3 162.450 MHz
Channel 4 162.475 MHz
Channel 5 162.500 MHz
Channel 6 162.525 MHz
Channel 7 162.550 MHz
Hope this helps.
Posted on Sep 06, 2010
  • 10,319 Answers
The frequency diode for the weather band will shortly give out were nothing will be heard. time to replace it if possible
Posted on Sep 04, 2010
  • 3,083 Answers
You're right about the different bands having different components to choose the various frequencies, and that looks like where your problem lies. Not an easy fix. In the old days, each band was made up of discrete components that had tuning capabilites, so when you identified a circuit, you could tweek it, although it usually required complex signal generators and an oscilloscope, at least. These days, the components are largely ICs and surface mount ceramics- things that require replacement, versus re-tuning. It's probably cheaper to buy a new radio than have it fixed, but you can check. Eton's support page is here:
http://www.etoncorp.com/CustomerSupport
Hopefully, they will replace it for you, depending on how long you've had it, etc.
Wish I had an easy "fix", but good luck, thanks for using FixYa, and hope this helps.
Dewalt DSCN1360 tuner problem
Don't you have an automatic tuning system or ATS? By pressing a band switch for a while the ATS starts looking for stations and stores the ones that have a good enough signal. Even if a station broadcasts but the location of the radio is not adequate for a good signal to be received, the station won't register and it will appear to you that the tuner is skipping.
Dec 02, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tuning knob turns but does not move tuner bar nor change station. all else works fine.
The linkage between the tuning knob and tuner bar (string?) has failed. Disassembly will be required to repair.
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
Tuning-suddenly stopped. knob turns, yet does not move station indicator bar and i cannot change station. all else works fine. options?
TAKE THE KNOB FO AND SEE IF IT WILL TURN BUY HAND IF SO JUST PUT A BIT OF PAPER ROUND IT AND PUSH THE KNOB BACK ON AND IT SHUOD GO
I need a new antenna for my Eton FR300. Where should I look?
Regards, Tony
Jul 24, 2011 | Eton FR300 AM/FM/Weather/TV Radio
How do I set my Eton Fr400 to get weather alert? Does it need to be on a particular station? Should it be turned on?
Free PDF Manual at the link below detailing how to setup.
http://www.etoncorp.com/upload/contents/307/FR400_Manual_0107.pdf
Please post State, County & ZIP is you need any assistance with your weather station frequency.
Please leave feedback.
Cheers
Andy
Apr 28, 2011 | Eton FR400 Radio
Where can i get an owner's manual?
jojmwright,
http://portablemedia.manualsonline.com/manuals/mfg/eton/fr300.html
-Chris
Sep 05, 2010 | Eton FR300 AM/FM/Weather/TV Radio
I need an online manual
I just upload a user manual for your device at fixya site. It will be available soon at this link.
If you can't locate it send me an e-mail adress to post it for you.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Jun 13, 2010 | Eton FR300 AM/FM/Weather/TV Radio
How to get TV audio on the FR300 radio?
Your TV band radio won't work anymore now that the US has switched to digital broadcasting. The frequencies now in use aren't the same now, so the radio can't receive them. Plus, the radio doesn't have the circuitry to decode the digital sound even if it could pick up the broadcasts.
Sad to say, you have a radio that now picks up only AM/FM/weather and static. Also, as far as I know, nobody is yet marketing a radio for TV sound with digital capability. All you can do during a power outage is use a new TV with battery capability and digital tuning.
Mar 02, 2010 | Eton FR300 AM/FM/Weather/TV Radio
My antenna broke, i purchased new antenna but when I tried to install new antenna the old antenna fell inside of radiio, I took out all the screws but still cannot get radio apart
On the back panel, there is a black decal located near the center. Warm this decal with a hair dryer (warm it, don't get it hot)Slip a knife blade under the right side and lift it up. Remove the hidden screw under the decal, and the the other five and the back will come off. replace the FM antenna and you are good to go. I had the same problem. mcarmich
Jun 13, 2009 | Eton FR300 AM/FM/Weather/TV Radio
I've lost the operating manual for my Eton FR-300 emergency radio
Your radio does not offer the S.A.M.E. capability that would let you receive alerts for just your specific area, but it will let you receive all alerts broadcast by the NOAA station that your radio is tuned to. Here is a link to the owners manual where you can find more details:
http://www.etoncorp.com/upload/contents/307/U070165_FR300_Manual_US_053107_low.pdf
Bill B.
San Antonio
Mar 28, 2009 | Eton FR300 AM/FM/Weather/TV Radio
Eton FR300 AM/FM/Weather/TV Radio Logo
Top Eton Audio Players & Recorders Experts
Mike carichael
Level 1 Expert
k24674
RobertFonner
RobertFonner
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
