Question about Clarion APA2160 Car Audio Amplifier
No power i can have my radio on and the amps is fine,but when i out in a cd my amp shuts off any ideas???
    Problem Solver:
  • 14 Answers
You have the wrong wire hooked up to the 'remote' input on the amp. The remote input waits for a discrete 12v+ signal from the radio. You have the 'power antenna' wire hooked up to the remote input. The power antenna lead shows 12v+ when the radio is on, but as soon as you change the source to CD, the power antenna drops the 12v+ and shuts your amp off. If you're radio has a blue/white wire, use that to turn the amp on instead of the blue wire you are currently using. If there is no blue/white wire, either the radio uses a non-standard color or the radio does not have the necessary wire. In the case that there is no true 'remote' wire, you can get away with using the accessory wire to the radio. That would be the red one. Jump that one over and you'll be running.
Posted on May 11, 2008
Radio plays fine no music comes out on cd, aux, or I pod mode radio sounds great any ideas
Are you using an ampilfier? If so, it sounds like you are using the power antenna remote, (blue wire) instead of the amplifier remote (blue/white) to turn the amp on. The power antenna remote turns off when leaving tuner mode, turning the amp off.
May 30, 2015 | Car Audio & Video
Is there a fuse or someting for the CD plyer or radio? My CD player wont work.
there is a fuse in fuse box that powers radio...sounds like a problem with radio itself....if fuse was bad it simply would do nothing"no power at all.
Aug 16, 2012 | 2005 Buick LaCrosse
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
Switches off when playing a cd. Fine on radio
sounds like you have the power antenna remote wire (blue) instead of the amp remote wire (blue/white stripe). when you go from radio to cd the power antenna wire shuts off.
Jun 11, 2010 | Kenwood KAC-8101D Car Audio Amplifier
Amp shuts off when switched from radio to cd
your amps rem wire is hooked to the power antenna wire on your head unit and so when you turn off the radio you would nolonger need an antenna so it powers down and would lower the antenna.Depending on the head unit you should have one output for the power antenna and one for the amp rem......If your head unit doesn't have the rem output you can wire it to the switched wire that powers your head unit but keep in mind the amp will stay on while you have the key in acc or run position even if your head unit is off.
hope this helps!
Jan 16, 2009 | Kenwood KAC-9152D Car Audio Amplifier
My amp only powers the subwoofer when the radio is on but wont when the cd player is on
The person(s) who hooked up your system made a boo boo. They wired your remote turn on lead to the power antenna lead instead of the amp turn on line (both are blue and easy to mix up). Thus when your radio is on it sends a signal to the amp and the amp turns on, but when you set to CD the signal goes away and your amp shuts down. Easy fix, just re-wire the amp turn on lead and the problem will be fixed.
Jun 24, 2008 | Rockford Fosgate P3001 Car Audio Amplifier
Volfenhag ZX8300 on with radio, off with cd or mp3 player
You're using the wrong control wire. You're likely using a wire marked antenna control. You need to use the one marked amp control. They are both blue.
May 22, 2008 | Ultra Linear UL-2200D Car Audio Amplifier
Alpine 9881 cd will not play sound
If you had to connect the remote amp turn on lead from the headunit to the factory amp turn on lead you may find your problem there.
On many headunits there are 2 blue remote wires 1 for antenna and one for amp turn on. The antenna remote only supplies power when the radio is playing not when playing CD's. If you hooked the antenna wire to the amp trigger then the amps shut down when you play a cd. If that's not it let me know and I will research further.
Jan 04, 2008 | Alpine CDE-9881 CD Player
Amp problems
did you run your 12+ to the battery? did you supply a sufficient ground of least 2x the size of the power lead?..did you hook up to the amp turn on lead and NOT the power antenna? model numbers of radio and amp would really be helpful...my email is troublerst@hotmail.com send me specifics and we will work it out
Nov 07, 2007 | Car Audio & Video
No output when I play a CD
what kind of vehicle do you have? i am going to guess your vehicle has a stock amp that it uses to power your speakers? you will have to hook up the remote wire for the amp to the wire that powers the amp in your vehicle (the stock amp) right now it seems like you have the "power antenna" wire hooked up to the stock amp in your vehicle.
Aug 24, 2007 | Eclipse CD7000 CD Player
Clarion APA2160 Car Audio Amplifier Logo
110 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
