Question about Whirlpool Duet GHW9150P Front Load Washer
F 32 erroe code
The f32 erroe code keeps coming up and does not work
  • 3 more comments
  • Anonymous Jul 16, 2008
    yes on the first wash!!!!
  • 5827 Sep 05, 2008
    I also have the F32 error code also. The machine acts like it's going to work, then locks up and quits.
  • bowhunting10 Dec 07, 2008
    I am writting this as the Lowes installers are here trying to fix my out of the box washer, can you believe it! the guys are great! but I am already having serious concerns with Whirlpool.
  • caseytrussco Apr 08, 2009
    ERROR CODE F32, WASHER LOCKS DOOD SOUNDE LIKE IT WILL START THEN NOTHING AND DOOR STAYS LOCKED. I HAVE TO UNPLUG TO GET DOOR OPEN. I AM OVER MY WARRANTY BY 10 DAYS, IS THERE A GRACE PERIOD I COULD FALL INTO IF I HAVE TO MAKE A SERVICE CALL?
  • Anonymous Mar 15, 2014
    erroe lei i display
    President:
  • 1,294 Answers
Plug off the wall. Open up behind, you will see a thin tube coming down from the control panel (pressure switch to be precise) to the waste area below. Disconnect this carefully from the top, blow into it, air should pass thru, it shd not be clogged; refit carefully. Before refitting, fit a similar tube to the pressure switch & blow - you should hear a click; if not there shd be a problem with your pressure switch. Anyway refit your old tube & try the machine.
Dont forget to refit the main exit hose at the position you found it. Rate me pl.
Posted on May 11, 2008
F32 codewhirlpool duet ht frontload washer F 32 code Whirlpool ht frontload washer displays f 32 code
F32 is a pressure switch failure. It controls the water level in the washer. The switch is a round plastic part mounted on the right panel towards the back right corner. Remove the switch by disconnecting the wire harness and the rubber tube connected to it and gently rotate it 90 degrees CCW and you should be able to pull it out easily. Some suggest that blowing on the tube will clean out anything that could be clogging it as a quick fix. If you suspect the switch you test it by checking two things; Blow on the inlet that was connected to the rubber tube you should hear a couple of clicks. The second test is to check if the switch works electrically. If the switch is bad you will need to replace it.
Read more: http://forum.appliancepartspros.com/washer-repair/7456-whirlpool-duet-f32.html#ixzz3S9ubaYUd
Feb 18, 2015 | Whirlpool Washing Machines
What does F32 mean
f32 is usual pressure switch failure
Feb 09, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
WHAT IS THE REASON OR CAUSE POSSIBLE FOR WHICH IS IN CODE F32
I did a "GOOGLE SEARCH" on 'KONICA MINOLTA 1312 ERROR CODE F32" and this was the results. Hope this helps!
F32-01, -02, -03, -04, -05, -06, 07Fan motor problem, AC board or ADU stand drive board
Apr 21, 2013 | Konica Minolta 1312 Black Toner Cartridge
Ecm bcm error code f32 was on smelled something burning now its not coming on and car has been stalling
You may have more than one problem.
The code F32 is for a problem between the engine computer and the body computer, or a loss of memory. To fix that someone would need to check the ground connections and the harness between the two computers.
The engine could be burning coolant like the head gasket problem you mentioned.
Dec 13, 2012 | 1993 Cadillac DeVille
My Whirlpool Duet has just come up with F32 error on display. Any ideas please?
I checked my code book and there is no f32. you should have a code tech sheet. this would be located on the bottom panel insid the washer. Check to see if they have a f 32 code.
Nov 06, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer is throughing a code
Here's a solution from an old posting of the same problem in a different Kenmore washer:
F32 is the code for a Water Level Switch Failure.
1. Remove the top panel from the washer by removing thethree screws in the top back of the washer.
2.Inside the back rightcorner is a round plastic box, fastened to the side with a plasticsnap. In will have a wire connector and a small, rubber hose connectedto it.
3. Check to make sure all the connector wires areconnected and tight. Unplug washer for 30 seconds to reset it. If the cycle failsstill with the F32 code, you'll need to replace the Water Level Switch.
4. Ifthe Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Aug 09, 2009 | Kenmore Washing Machines
Error F32
the error is COF32. You have to check the developing unit, to change the developer is needed and to run atdc auto adjust.
Apr 16, 2009 | Konica Minolta bizhub 180 All-In-One...
F32
We found out that the F32 code means you have a faulty pressure switch. From my online research this is a common thing with the whirlpool.
We had just bought it and the next day when it was delivered we were excited to try it out and got that bloody F32 code...luckily 2 days later we got it fixed by a repairman.
I have know idea why Whirlpool would make a product with all sorts of codes, but no explanation as to what they mean. That makes no sense.
Jul 24, 2008 | Whirlpool Washing Machines
Kenmore elite HE 3t washer
1. Remove the top panel from the washer by removing the three screws in the top back of the washer.
2. Inside the back right corner is a round plastic box, fastened to the side with a plastic snap. In will have a wire connector and a small, rubber hose connected to it.
3. Check to make sure all the connector wires are connected and tight. Unplug washer for 30 seconds to reset it. If the cycle fails still with the F32 code, you'll need to replace the Water Level Switch.
4. If the Water Level Switch does not eliminate the F32 code, it then the machine controller may have failed.
Jul 04, 2008 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
162 people viewed this question
Dan Webster
Dan Webster
Sal De
