Question about Cameras
Need manual for canon power shot s50 - Cameras
  • Cameras Master
  • 4,738 Answers
Go to the following link, and select the "Drivers and Downloads" tab. The S50 user guide should be listed, and downloadable in PDF format:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=322&modelid=8778
Posted on May 11, 2008
Hi i've been given a canon power shot s50 camera, but with no instruction manual, how can i aquire one , thank you, regards Roy.
Here is a link to a free downloadable user manual,no pop ups either.I use this site all the time because it has a wide variety of products,and the best range available as far as discontinued items,which yours seems to be.Once downloaded,it will keep your records from downloads without having to sign up for anything.Bookmark the page for future references and if you print it,play with the sizes at the top of the download by adjusting the % for the best size for you.If you go too big,it may cut off some of the info.Good luck,Greg
http://www.retrevo.com/samples/Canon-Digital-Camera-manuals.html
Oct 29, 2010 | Cameras
Camera will not power on with battery or ac
Theres a 1.6 amp fuse on the circuit board that needs replacement, and also two transistors kz 3 b1 and jp 3 b2, but I can't find the transistors online anywhere. If you find them tell me. Thanks.
Dec 28, 2009 | Canon PowerShot S50 Digital Camera
I found a canon power shot camera but need a manual and charger.
You can download manuals here. Also, if you click on the tab marked "Supplies & Accessories" (center of page), you can see the part number for the charger, and order one from Canon if you want.
Oct 01, 2009 | Canon Cameras
Please explain how to use the flash card with the camera
Manuals fo rthe S50 alavailable on the Canon support site.
May 19, 2009 | Canon PowerShot S50 Digital Camera
How do I get the time and date to print on the pictures for my canon powershot s50 camera? I do not have the manual.
go to the menu and set it up
you can play on the menu, JUST DO NOT FORMAT your card, as it will erases all your images.
Apr 15, 2009 | Canon PowerShot S50 Digital Camera
I have a canon Power Shot S50. The mechanical slider that covers the lens is loose. When I open it, it doesn't power up the camera. I suspect there is a switch underneath the cover is broken.
The open door button on a circuit board is usually micro. A loose cover will likely not make contact with this small switch. Take the cover off and tighten the screws on the inside. Try to locate the switch to inspect if it has been wore off, broken, or missing even.
Nov 13, 2008 | Canon Cameras
Canon sliding lens cover door
I have been having the same problem. Once opened, the sliding door will not close and the lens won't retract. But I have found that if you plug the camera into a computer via a USB, the lens then retracts enabling you to close the lens cover.
I'm still trying to find a way to fix this problem, since this is a great camers and still takes fantastic pictures.
Apr 21, 2008 | Canon PowerShot S50 Digital Camera
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
