Question about Kenmore Elite HE5t Washer
We have a Kenmore Elite he5t front load washer, and this morning when I loaded and started it, it made a clicking noise that seems to be connected with the water filling. Last time it was used it worked fine.
  • shakeysis Sep 03, 2010
    The noise start as soon as you start the washer and the door locks.
    As soon as we start our kenmore washer, and the door locks, it starts making a non stop clicking noise. The last time we used it it worked fine.
  • 15,935 Answers
The solenoid on the water valve is likely failed.
Replace the dual inlet water valve.
Thanks!!
Posted on Sep 03, 2010
  • 2,272 Answers
Unscrew the hot and cold water inlet valves if the washer is not filling up quickly enough or filling very slowly or filling with water but making unusual clicking noises.If the water is filling properly in the unit but making noise in the spin cycle then the spin bearing and motor bearing needs to be checked. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. If its making noise while drain cycle then check the drain hose and drain pump .If anything is got blocked .If all checked ok then the motor control board and the spinning motor needs to be checked,also check the drum ,spin in manually and check if its making noise then either drum is out of alignment or any other object is blocking the drum from getting proper spin.
You can get required parts from www.repairclinic.com
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
  • raj somaiya
    raj somaiya Sep 03, 2010
    If the clicking noise comes directly as the door locks and machine starts then,
    Could be the motor or a relay .
    A clicking sound quite often is a relay with a coil dying. The coil pulls in the contacts, but can't hold them. It could also be a solenoid that shifts gears in the transmission. In both parts, a energized coil pulls a shaft in. In the solenoid, it is mechanical, where in a relay, the action is to move contacts switching a load.If the clicking is non-stop in all cycles or any cycle getting stopped in between then the timer has to be checked and replaced.as the faulty ti,mer will make clicking noise before going completely bad.
    Thanks for keeping updated with your query.
I hit the delay button for 2 hours yesterday on my kenmore elite front loading washing machine and nothing has happened and the door is locked
unplug it and wait for the machine to reset. You should hear some clicking noises. May take a while for it to reset.
Jun 28, 2014 | Kenmore Elite HE5t Washer
He5t tearing clothes
Are you sure that the clothes are not getting caught on exposed zips.
Why not load some things like towels sheets (without zips/buttons etc) in the washer and see if the issue repeats itself. You should also be able to see if there are any sharp edges or loose sharp items in the drum (mind your fingers)
Dec 14, 2013 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Instruction of how to change bellow of kenmore elite he5t front load washer
See if this video helps you. It is for an HE3 but should be about the same process.
Nov 27, 2012 | Kenmore Elite HE5t Washer
Where is the presure switch locate at on a Kenmore Elite HE5t. Is there a diagram of it?
Take off the lid of the washer. In the back right of the washer it has a small hose attached to it
Aug 24, 2012 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
HE5t Steam shows SUD then f35. I have unplugged it. Plugged it back in; started a rinse only cycle and still it show this error. The washer is empty. I check the sensor on the back right hand area that I...
SUD means there are too many soap suds in the washer. Are you using a front load approved detergent? Are you using the correct amount? or slightly less is better.
May 12, 2017 | Kenmore Elite HE5t Washer
Kenmore he5t shaking when it spins
hi..you have an unbalanced load.Make sure it is evenly
distributed inside of the washer and don't overload it.
try this out..
thank u..
kindly rate my response..
May 17, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore he5t
this looks like a classic whirlpool control board issue. fault is a communication error between board and panel. check connections.
whirlpool always recommends replacing both at same time. very common problem.
Jun 01, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
397 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
