Question about Echo Inc. 44 CC, Carb Certified Backpack Blower
I have an Echo PB 403 T that idles just fine, but it will not accelerate to full speed. When pressing the throttle towards full, it stalls. I have checked the muffler; it is clean. the air filter is clean. any ideas as too what to check next? any help would be appreciated. \r\n Thanks
  • 5 Answers
SOURCE: Echo Blower dies out when full throttle
Find the fuel air mixture screw located by the carb and turn it so the moter starts to slow down then turn it so the blower runs smoothly this should keep it from dying out
Posted on Nov 23, 2008
slohry
  • 87 Answers
SOURCE: echo blower motor will not rev.full throttle--only about half
Check the insulator block and associated gaskets behind the carb. Sometimes the insulator block crack and reduce the amount of vacuum to the pulse diaphragm.
Posted on Apr 10, 2009
  • 31 Answers
SOURCE: I have an echo pb 265l leaf blower. It starts
If its a two cycle engine it sounds like its loading up on fuel.. Need to lean out the fuel on the carb. Not much or it will be to lean an stick the piston..
Posted on Sep 23, 2009
petersfan761
  • 92 Answers
SOURCE: engine stalls after acceleration
Sounds like its not "un-choking" it self, that its running like its still choked like you wold at initial start up.
Disassemble it and see if u can pysically see the activation and deactivation of the choke when u apply them.
While u are at it, also make sure:
Gas is fresh?
MIx is right?
Plug is good?
Chain brake mechanism is released.?
Good luck.
Posted on Oct 05, 2009
dontbother10
  • 2220 Answers
SOURCE: My echo cs440 all of a sudden stopped running at
That is where I would go. Maybe carb clean or kit if it is a sudden change.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 01, 2010
Echo pb 255 throttle cable attachment
try parts tree .com they have decent diagrams..
Aug 27, 2014 | Echo Power Blower PB-255
Have a PB-250, ran great but now only runs full throttle, does not idle low.
You've been running the unit with the wrong oil to gas ratio and now the unit runs rich - there is no real way to fix it at this point - you can adjust the carb but it will not probably hold the idle you desire - but then again blowers are to be ran wide open 85% of the time so don't sweat it too much on this unit but practice better maintenance and a proper mix ratio in the future.
Oct 05, 2012 | Echo PB-250, Handheld Blower,
Dies when gas pedal is pressed
This engine has automatic idle speed control, the computer controls a "air bypass" valve on the side of the throttle body where the air intake hose from the air cleaner is connected, the valve and the throttle butterfly get "sludged" up and this causes all kinds of idle problems and off idle stall, see full list below and fix for the problems
Here is the common cause of surges, cold stalls, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours.
To correct this problem Buy a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, NEVER USE CARB CLEANING SPRAY, IT DESTROYS THE ANTI-STICK TEFLON COATING, spray it into the air intake through the throttle body of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is now clean, if you continue to have the idle speed control problems you may need to seek the help of a professional.
Dec 04, 2011 | 1991 Ford F150
My Echo CS starts fine but then will not accelerate. Sometimes, after it's warm, it will work OK, but more often, it acts as if the chain lock is engaged and almost wants to stall as the throttle is...
Can the chain be pulled by hand fairly easily? Check the fuel filter, air cleaner, and muffler for plugging. Inspect the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. Try turning the H jet needle CCW about 1/8 turn--the engine should 4-stroke when running free at speed, but 2-stroke when cutting. Hope this helps!
May 12, 2010 | Echo CS400 18" Chain Saw
Brand new echo pb-251 blower, used it 3 times for 5 minutes each time and it worked perfectly, now the fourth time using it the engine starts easy and idles but engine sputters and misses when pressing...
you can thank the EPA for your blower problem the EPA makes all brands of lawn equipent "tamper proof" with plugs and limit caps. not just echo......when we service an echo piece of equipment we let it "break" in and adj the carb as needed BEFORE it leaves my shop. dont hesitate to bring it back to the dealer, if they are reputable, they will do the adj while you wait......hope this helps. good luck
Nov 21, 2009 | ECHO, Inc. PB-251C Handheld Blower
Engine stalls after acceleration - Start fine, idles fine, but won't run at full speed. Engine dies when throttle is engaged more than half-way. Fuel filter is ok, air filter has been cleaned.
Gas is fresh?
MIx is right?
Plug is good?
Good luck.
Oct 04, 2009 | Echo Garden
Echo Inc. 44 CC, Carb Certified Backpack Blower Logo
127 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
