Question about HP Pavilion F1523 15" LCD Monitor
Monitor doesn't display any information. All hookups are in tact.
  • HP Master
  • 4,737 Answers
While it is still power on, unplug it from the video port of your computer. Can you see anything on the monitor? If so, the problem is with your computer. You need to troubleshoot. First try the monitor on another computer and verify that it's working fine. If it's not, then ask for repair and if it would cost some around $200, I don't recommend, you'll get a bigger and better new monitor for $200.
If you think there's nothing wrong with the printer and is tested ok, then start working with your computer, first try with another monitor and boot up, probably it shouldn't work, if it does, then the cable you were connecting the other monitor must be the faulty.
The best thing you can do with a dead video computer is to re-seat the Rams, Power connectors and Bios battery. First remove the Ram/s and boot again, you'll hear the beeping, means there's no ram installed. After cleaning the ram, again install it/ (if there are multiple rams, install only one), now boot again. same problem, try again with the other ram.
If you see no changes while working with the rams, then it must be the bios or the video card itself. If you have a spare graphics card, try it or if you don't have one, then the only solution is to replace the motherboard.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
GA-8SIMLH no disply
Check display power, monitor connector , if this doesn't help give us more information. How much RAM, what graphics card, Which Operating System? Is there a light on the monitor. Is the ram new?
Jan 23, 2012 | Gigabyte Computers & Internet
Tip
LAPTOP to TV Connection
Many people today want to connect their computer to a TV. Most HDTVs today have a VGA input for computer hookup. Most laptops also have a VGA output for external display. Using a male to male VGA cable, the computer can use a HDTV for a display. Sound is connected using a 3.5mm audio cable. See this web page for complete details.
http://columbiaisa.50webs.com/laptop_to_tv.htm or this webpage
http://sites.google.com/site/columbiaisa/laptop_to_tv
The screen resolution setting determines how much information is displayed on the display screen. It is measured horizontally and vertically in pixels. At lower screen resolutions, such as 640 x 480, fewer items will fit on the screen, but they will be larger. At higher resolutions, such as 1600 x 1200, more items will fit on the screen but they will be smaller. The resolution options will vary with each computer based on the video card device, monitor size, and video & monitor drivers. If the screen looks distorted or fuzzy, then you may have an incorrect screen resolution size set for your monitor. In Windows you can change the screen resolution to match the TVs capabilities. Go here to view a video on how to change screen resolution:
http://windows.microsoft.com/en-US/windows7/Change-your-screen-resolution
on Aug 23, 2010 | Televison & Video
I am attempting to connect my HP pavilion dv9000 to a HP 2310e monitor, but it doesn't recognize the monitor via the HDMI cable
You must make sure it's configured correctly: make sure the monitor is up and running (not in Sleep) , that the HDMI cable is firmly plugged in (use a new one to be sure), then right click on the desktop, click NVidia Control Panel, under Select a Task expand Display and click Run multiple display wizard . If the monitor isn't picked up then go to Set up multiple displays options and see if the monitor appears in the second setting (Select the displays...) - if it doesn't then click the MY Monitor is not shown in the list option and follow the procedure to force its detection.
If even that fails then the video driver is corrupted, you will have to uninstall it, download the latest one and reinstall it.
Use this one
http://www.nvidia.com/object/geforce_notebook_winxp_179.48_beta.html
Aug 12, 2011 | Computers & Internet
Please help.. my monitor has no display and my don't even beep. the LED in the monitor turns back to orange after few seconds. cpu, disk drives and ram are working..
This is one of the serious problem that arises because if you set your monitor with a high resolution with high frequency, then the monitor doesn't display anything as it's frequency is out of the rang or limit of the monitor's actual resolution capacity. Each monitor will have a limit of max frequency that is said to be the Refresh rate (for each and every resolution setting the display is refreshed.) When high resolution is set with high frequency that is not supported by the monitor, it then display a message like "frequency out of range". If you press ESC key within the few seconds of this setting, it will revert back to its initial resolution. But if you continued with the setting of same High resolution with High frequency, the monitor is not going to display anything because its frequency is out of the range. Most of old monitors like CRT's etc doesn't support 1024×768 at a refresh rate greater than 60Hz.
Jun 20, 2011 | Asrock P4I45GV R5 Motherboard
How to hook up speakders?
The monitor does not have output sound since it is only an input device. You will have to hookup the speakers to your device (laptop, computer, gaming console) that you are connecting to the monitor. The speakers in the monitor are ready to receive a signal so that it can amplify it and let you hear it. If you hookup your speakers to the monitor it is the same as if you were trying to hookup two sets of speakers to each other.
Nov 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
I want to hookup my laptop with my 7.1 Onkyo HTR540 home theatre, onkyo has optical input, i am confused how to hookup with my laptop which also has HDMI port but my home theatre does not have HDMI Port
If you have a plasma, or otherwise HDTV display, what you would do is send you information in two different directions.
Connect the video directly to the display. Connect the audio through your home theater, and set both units accordingly.
Apr 11, 2009 | Audio Players & Recorders
Hookup external monitor to my laptop
look at the F keys on your laptop (F1, F2....)
find one that has a monitor picture on it. if you have one (mine is F8), hold the Fn (function) key and that F key.
that should turn the external monitor on
Mar 13, 2009 | Computers & Internet
Wiring problem
waste of time.
if you need a monitor, buy a monitor.
if you need a tv, buy a tv.
Sep 27, 2008 | LG Studioworks 700S 17" CRT Monitor
DVI connection not working
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Jan 29, 2008 | HP f2105 21" LCD Monitor
Power button won't turn off monitor
Well, I noticed this after I installed win xp sp3. My monitor won't turn offwhen I click the button. I have to set my power setting to a certain timeframe then require a relogin but the monitor just won't turn off otherwise.
Oct 23, 2007 | Sharp LL173C 17" Flat Panel LCD Monitor
HP Pavilion F1523 15" LCD Monitor Logo
37 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
