You said to take all the screws out of the bottom laptop and to take out the memory and hard drive to get to the CPU Fan. Won't the hard drive lose all the data when I take that out? Instructions on Model P205-S6337. To Technical 114
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 88 Answers
Hi
A hard drive will retain its datat even if removed, so long as it's replaced back into the laptop no data loss will occure
Posted on Sep 03, 2010
How to remove the back cover of a Panasonic CF-W7 laptop in order to to replace the faulty exhaust fan?
LOL, ok, close the lid, remove the power cord, remove the battery, then turn the laptop over and start removing screws. You better write the screws down on a piece of paper or put them in a cup with a piece of paper that identifies where they came from. Sometimes removing the bottom is not all there is to it. You will probably have to remove the lcd screen, keyboard and palmrest to get to the fan. Good Luck!!!
Oh, by the way, there will probably be screws in the hard drive case, the battery case and all along the palmrest as it is secured to the motherboard. So you will also need to remove the hard drive, memory, CD/DvD Drive, wifi card, and most definitely the Heat Sink that most ime houses the fan and is on top of the CPU. You'll need some Thermal Paste to put back on the Heat Sin and CPU once you remove it. Otherwise most times your laptop will not boot if metal touches metal, or it will run hot and shut down if the coat of Thermal Paste is too thin or has dried up.
Mar 30, 2012 | Panasonic Computers & Internet
How do you replace the fan on a Fujitsu s2210 laptop?
How to Replace a Fujitsu LifeBook S2210 Fan
1. Follow your laptop owner's manual and assembly guide carefully as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, DVD drive , Ac adapter and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive, screen sled.
3. Turn the laptop over and remove the screws on the bottom that hold the keyboard in place. Flip the laptop over, open it, then lift the keyboard up and out. Unplug the flexible ribbon cable that connects the keyboard to the motherboard.
4. Remove the screws that hold the laptop keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the Fujitsu LifeBook S2210 CPU Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and cpu cooling fan. Replace the screws, plug the Fujitsu LifeBook S2210 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new Fujitsu cpu cooling fan running and feel warm air blowing from the vent on the side of the laptop. A Fujitsu LifeBook S2210 Fan does not run continuously, so don't be concerned if the Fujitsu LifeBook S2210 Fan shuts off periodically.
Jun 26, 2011 | Fujitsu LifeBook A series AH550 NoteB......
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
May 10, 2011 | Toshiba QOSMIO E15-AV101 Notebook
Where can I find a schematic or instructions to open my toshiba satellite u205-s5067 laptop. I want to clean/replace my fan.
Taking apart a laptop to change the fan is a relatively simple task. Just keep track of where all the screws go and follow these steps:
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Satellite U205-S5067 Fan cable.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Satellite U205-S5067 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Satellite U205-S5067 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Satellite U205-S5067 CPU cooling fan cable into the circuit board.
Hope this helps.
Apr 05, 2011 | Computers & Internet
Laptop fan has a noisy and pc is shutdown after some time ..so can I replace the fan ? pavilion dv3-2175ee
How to Replace a HP Pavilion dv3 Fan?
1. Follow your laptop owner's manual and assembly guide carefully you can download this from HP web site as you disassemble the laptop. Touch something metal periodically to remove static charge, and work on a large table with a bright light source.
2. Turn off the laptop and unplug it. Remove the main battery, CD/DVD drive and the hard drive. The hard drive is usually located in a slot on one side of the laptop. Remove the screw that holds the cover in place, then pull out the hard drive sled.
4. Remove the screws that hold the keyboard bezel and palm rest in place. Carefully pry loose any plastic snaps on the sides, then lift the bezel and palm rest up and out.
5. Unplug the HP Pavilion dv3 Fan Cooling Fan. Remove the screws that hold the heat sink and fan in place, then remove the entire unit from the laptop. Remove any thermal compound residue from the bottom of the heat sink and the CPU.
6. Apply a thin layer of thermal compound on the CPU, then replace the heat sink and fan. Replace the screws, plug the HP Pavilion dv3 Fan back in, then reassemble the laptop.
7. Plug the laptop in and turn it on. After you use it for a few minutes, you should hear the new fan running and feel warm air blowing from the vent on the side of the laptop. A HP Pavilion dv3 Fan does not run continuously, so don't be concerned if the HP Pavilion dv3 Fan shuts off periodically.
Jan 10, 2011 | Computers & Internet
Have a Toshiba LAptop Model A215-S7413 and Overheats and turns off. How can I fix it or open it to clean the Dusty Fan on the Bottom? Thanks, AUgie
Once there is no proper vent , the laptop will go off due to over heating, try to always place the laptop in a position where breeze can be reaching the panel from underneath where the fan is.
To disassemble the laptop, follow the steps below:
Turn the laptop over and remove the battery and the CD/DVD-ROM drive.
Remove two screws securing the laptop memory cover and remove it.
Remove two screws securing the laptop hard drive.
Remove the laptop memory module.
Slide the hard drive to the right to disconnect it from the system board and remove the hard drive.
Remove all marked screws on the bottom of the laptop.
Insert a sharp object under the keyboard securing strip and carefully start lifting it up. Continue removing the strip with your fingers.
Be very careful with the strip because it has a control board attached to it.
It might take some time to remove the keyboard strip.
Remove all the screws around the lower bottom and you will have direct access to the fan.
Reverse the process to reassemble the laptop back together.
Take care and good luck
Dec 02, 2010 | Toshiba Computers & Internet
Need to remove cpu fan
STEP 1Always start laptop dis assembly with removing the battery.
STEP 2
Remove six screws securing the hard drive cover and the heatsink covers.
STEP 3
Remove one screw securing the hard drive to the laptop base.
Disconnect the hard drive and remove it from the hard drive bay.
STEP 4
Remove three screws securing the CPU heatsink to the system board.
Carefully lift off the heatsink off the laptop CPU.
STEP 5
The heatsink is 100% clogged with lint.
If your heatsink is clogged, clean the heatsink with a canned air to prevent your laptop from overheating.
Mar 08, 2010 | Toshiba Satellite A45-S150 Notebook
Laptop will not come on
Although other possibilities can be at fault, if it does so little after power on, the CPU itself may have failed. The very first actions a PC does when turned on is to read the information stored in the CMOS to determine what hardware is on board. After doing this, it turns to the hard drive for a check to see if it is readable and then the CPU (your microprocessor) Intel or AMD takes command. If the hard drive is at fault, a message will inform you that the hard drive either cannot be found or is unreadable. If the hard drive light flashes once, then the BIOS  has made contact and then the hand-off to the CPU begins. If it is stopping dead at that point, the CPU is the prime suspect.
What fairly often happens is first a failure of the CPU fan that sits directly on the heatsink that transfers the heat from the CPU and then the heatsink is bathed in air from the fan. If the fan has failed (all too common) or is impeded by a dust accumulation, the CPU overheats and if the maker has not made any provisions to shut down the CPU, it dies.
There is a possibility that this kind of problem can be caused by a failure of the RAM (memory) but establishing what has failed is only possible through substitution of one or both of those devices.
If you are somewhat skilled, opening a laptop requires small Phillips screwdrivers to remove case screws from the side(s) and bottom, then the case still (in most cases) needs to be carefully pried open. The mating halves normally snap together as well as being fastened with said screws.
Most likely the keyboard will also have to be freed from a couple of screws and, depending on the length of the flat cable connecting it to the system board, can be pulled forward before or after the cable is pulled.
The CPU will be easy to spot; it's one of the large clumps on the board. Check its fan to see if the blade turns freely and is not impeded by dust (these things have hardly any torque), then with two fingers, positioned on either side of the blade, check to see if it rocks side to side. This would be an indication that the bearings have failed and it will need to be replaced.    The CPU is held by clips but make sure you have no static charge before removing any internal part. Just 'equalize' the charge by touching an exposed metal cover or other chassis part. Memory is normally accessible from the bottom of the case.
Now comes the bad news; there are still myriad other components that can keep a PC from booting when no error message is present since there are numerous support functions which can interfere with the startup of system. I've given you the most likely points of failure; CPU or memory.
Jan 01, 2009 | Toshiba Satellite A105 Notebook
IBM T41 WILL NOT STARTS UP SOMETIMESTHEN WHEN IT DOES IT FREEZES
problems will be with:-
1:- installed memory ( not enough or damaged memory module ) RAM
2:- The Processor ( CPU ) Is Overheating.
3:- Hard-Drive. The unit may have bad or defective sectors.
4:- Computer Virus Or Similar.
Solution:- remove 1 memory module from the computer ( located on the underside computer ) boot the computer. see if this helps. try changing memory between the 2 allocated slots.
Check the CPU Fan, is not clocked with dust/debris. ( Can be accessed by removing 2 screws on the underside or the laptop ) Marked with >> or similar. remove the fan, 3 small screws and brush with a soft dry paint brush or similar, remove any dust from fan and check for blockages.
run a scandisk or hard-drive checking program, to test hard-disk unit et,c.
following these steps, should solve your problems.
Mike @ Compurepair. " Thankyou For Using Fixya "
Nov 22, 2008 | IBM ThinkPad T40 2373 Notebook
Laptop hp pavillion ze4300
Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
Jan 06, 2008 | HP Pavilion ze4300 Notebook
Computers & Internet Logo
David Payne
David Payne
