Question about Telex Audio Players & Recorders
I do not have a output cord to go to my sound system
    Prodigy:
    An expert who has answered 500 questions.
  • Telex Expert
  • 611 Answers
Visit a local music retailer to purchase a cord. The same places that sell drums and electric guitars will have microphone cables.
Posted on Sep 07, 2010
I can hear music and background sounds, but I can not hear voices through TV.
It's a 5.1 surround system which means every output has its unique sound.try the setting the sound to stereo,or just plug into diff. outputs till u get the right one
Jan 11, 2016 | Supersonic Sc-31 5.1 Channel DVD Player...
How do i connect my hitachi tv to my surround sound system i tried red and whit cables as thats all i can connect to my surround sound system bit it does not work
The red and white RCA cords from the TV 's AUDIO OUTPUT must be connected to the INPUT of the surround system. You can counter check the input of the surround with another input like a DVD/VCR and if this works the TV output must be absent. Check if the connection was given to the OUTPUT and not to the input.
If not there is fault in the preamp output of the TV sound amplifer. You need to use a signal source to confirm. If not the earphone output can be used with a resisitor network for impedance compensation.
Sep 20, 2011 | Hitachi Televison & Video
I am trying to hook up my playstation3 to my my sanyo plasma hdtv I brought the HDMI plugs when i hooked it up I have no video and no audio what do I do to fix it or do i need a plug for each one of my...
If you would like both video and audio to output through the HDMI cord, make sure to go into the PS3's video settings and select HDMI output there, and also go into the audio output settings and select HDMI. This should make the audio come out of the TV's speakers.
If you're using separate speakers, such as a surround sound system, use a different audio output (such as the red and white component cords) and plug those directly into your sound system.
Apr 24, 2011 | Sony Playstation 3 (PS3) Console
My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
1.
Confirm the formats supported by your audio device.
Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
2.
Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
3.
Select [Audio Output Settings].
4.
Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
Select audio output formats.
Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
soundoutput003.jpg 6.
Check your settings.
You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
soundoutput002.jpg 7.
Save your settings.
The audio output settings are saved on the system.
Hints
  • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
  • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
  • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
  • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
  • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
(Information taken from here)
Hope it helped.
Nov 18, 2009 | Sony Playstation 3 (PS3) Console
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
Outgoing noise from USB port on my UA-4FX
probably not the USB cord because the chances of a faulty USB cord are slim, and I think it's the computer or the input/output chord.
Nov 01, 2008 | Edirol UA-4FX External Sound System
Philips home theater system
Recheck that you hooked it up exactly as stated in the quick start guide. If there is no sound when playing DVD, return it immediately or call Philips to get replacement. If you get sound when playing DVD, but from no other sources, then make sure that the end of the cord NOT plugged into the Philips says OUT or OUTPUT - many TV's do not have outputs.
May 24, 2008 | Philips Audio Players & Recorders
Surround sound keeps shuting off
the system go to protect mode in case of trouble in output stage(power output component and cords and speakers.
try to connect each speaker one by one until you find the bad one change cord first for the bad one and check if not working you must change speaker itself.if all above does not solve the problem you must pass your sony to service center
Mar 23, 2008 | Sony HT-DDW700 System
Ht-ddw790
Check the setup menu on your TV. Many models require that you choose between using the internal speakers and using the speaker outputs. Sometimes the TV menu choices are "FIXED" (audio output) or "VARIABLE" (internal speakers).
Feb 05, 2008 | Sony HT-DDW790 System
60 people viewed this question
Top Telex Audio Players & Recorders Experts
Ben Armstrong
Sam Palermo
Sam Palermo
Vito Vacirca Jr.
Are you a Telex Audio Player and Recorder Expert? Answer questions, earn points and help others
