Question about HTC Touch HD Smartphone
My HTC hd2 phone went dead. When I switched it on
My HTC hd2 phone went dead. When I switched it on it just showed HTC in a white background. This happened several times now refuses to start up. Have tried removing battery and refitting to reboot. There is a small red button, have tried pressing that. Still dead. Notice its getting warm with battery charging.
    Habit-Forming:
    New Friend:
  • 106 Answers
Hi ,
your phone need a software upgrade take it to a service center and upgrade the software if not working the mother board may be defective. only an authorised service center can help you.
Posted on Dec 22, 2017
  • 56 Answers
SOURCE: HTC HD2 they gave me the wrong download for english
Well with the phone turned off, press and hold the VOLUME UP and VOLUME DOWN buttons, then press the END/POWER button shortly and release it. You will then see a message on the screen asking if you're sure about resetting it. If so press the VOLUME UP key. It should boot shortly after that.
Posted on Jun 02, 2010
cardenderek
  • 783 Answers
SOURCE: HTC HD2 not "booting up" I have an HTC HD2
take it to your service provider they will fix your problem on the spot usually or order you a new one free of charge. -Derek
Posted on Jan 10, 2011
  • 2069 Answers
SOURCE: I have a HTC HD2.
you should try to have it opened and inspected for mostly water damage. all those indicate to a fault motherboard. some components are shorting and causing the battery drainage.
this will require disassembling phone and be sure, this is a hardware problem not software.
regards
Posted on Jan 31, 2011
  • 171 Answers
SOURCE: my htc hd2 refuse to
Performing a factory reset via settings
  1. On the Home screen's Settings tab, tap Menu > All Settings > System > Clear Storage.
  2. Enter 1234.
  3. Tap YES to perform the reset, or tap NO to cancel the reset.
Performing a factory reset using phone buttons
  1. With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
  2. While holding the volume buttons, press the END/POWER button briefly and then release it.
  3. When you see a warning message on screen, release the VOLUME UP and VOLUME DOWN buttons.
  4. Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
By the way, do remember to backup your data first before hard reset
Posted on Feb 12, 2011
  • 9 Answers
SOURCE: Yesterday my htc desire was
It would be best to bring your phone to diagnose the problem. It could be a number of things, from software to hardware, so your best bet is to bring the unit to a service technician
Posted on Apr 16, 2011
Can I get the unlock code for tmob.. htc hd2
Hi. Are you asking the unlock code for a T-mobile network locked HTC HD2? If so, you can visit WickedUnlock.com and get the accurate unlock code at affordable cost.
..............UNLOCKING INSTRUCTIONS..............
1. Switch ON your HTC HD2 with a Not ACCEPTED SIM Card.
2. If your HTC HD2 asks for a PIN code, then enter your SIM card PIN and press OK.
3. HTC HD2 will ask to enter an "unlock code".
4. Enter Unlock Code we send to you.
5. Your HTC HD2 is now unlocked.
Jul 24, 2014 | HTC HD2 UNLOCK CODE For AT&T/ Cingular...
All i get is screen save display?
It seems you need to reset your phone.
If your HTC HD2 is frozen and a soft reset doesn't work, this guide shows how to restore your handset to its factory settings with a hard reset
There are two ways you can perform a hard reset on your HTC HD2. The first is best if your phone is still operational. If it has crashed and you can't get a response from it, you're better to try option two.
Performing a factory reset via the settings menu
  1. On the Home screen's Settings tab, select Menu - All Settings - System - Clear Storage
  2. Enter 1234 and tap Yes to confirm
  1. If your phone has crashed and won't respond, you'll have to perform a battery pull to power the phone off. Simply take off the back cover and remove the battery. Otherwise, just turn your HTC HD2 off using the power button.
  2. With your phone powered off, press and hold the volume up and volume down buttons
  3. While holding the volume buttons, press the power button and then release it
  4. When you see a warning message on screen, release the volume up and volume down buttons
  5. Press the volume up button to perform the reset when prompted, or press any other button to cancel the reset
How to reboot the HTC HD2 with hard reset
Mar 31, 2014 | HTC HD2 T8585
When I turn on my htc hd2 i get a all white screen. How can I fix that problem?
brother.
Some problem with u r HTC mobile.... U r Mobile software is not working ....
go to HTC service center and tell them to upgrade the software.........................
Have gr8 day
Jun 23, 2011 | HTC HD2 Smartphone
I was updateing my hd2 and it went dead what must i do
Sorry, but you will need to contact T-Mobile support. 1-800-T-Mobile. They may need to send a replacement phone or have you send yours in to repair.
Apr 29, 2011 | HTC HD2 Smartphone
How can I install Android 2.2 in my HD2,thanks.
Prerequisite to run Android 2.2 Froyo on HTC HD2
1. Flash HardSPL3 on HTC HD2
2. Flash any HTC HD2 Radio ROM Leo_RADIO 2.08 onward
Guide to install and run mattc Leo + Froyo w/Sense 1.7 build
1. Download zip file here.
2. Extract contents of zip file to your SD card. Note - Android folder should be located at root level (SD card\Android).
3. Using file explorer in Windows Mobile, inside the 'Android' folder run CLRCAD.exe (to fix audio issue). Don't worry, it will appear to do nothing, that is normal.
4. Run Haret.exe.
5. Enjoy...
Note - Android 2.2 Froyo on HTC HD2 is not perfect yet compare the actual Android phone HTC Desire. Some functions are not working. And I got white and black screen of death (SOD) sometimes. But it is getting better and better each day. Hoping it will out perform actual Android phone out there soon.
Mar 04, 2011 | HTC HD2 Smartphone
I have installed CHT editor software in my HTC HD2 around 1month ago.. It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem...
i have installed CHT editor software in my HTC HD2 around 1month ago..
It is working fine 4 me... Today i enabled the phone security code (simple pin) and also unlocked it many times b4 problem occurs..
bt after dat i switched off my phn n nw its demanding the security code which i entered d same with which i opened it many times...bt every time it is showing me wrong password... is there any solution 4 dat... i m pretty much sure dat i m entering d right password..
my mobile model is HTC HD2 T-mobile Leo, i bought it from USA n unlocked it in india...
Nov 24, 2010 | HTC HD2 Smartphone
Htc hd2,phone battery died,put on charge and turned it
take a look at this link i found, it shows you how to do a soft reset on your htc hd2:
http://www.htc.com/europe/howto.aspx?p_id=297&id=181
HOPE THAT HELPS.
Jul 06, 2010 | HTC HD2 Smartphone
Hi, i have smashed the glass screen on my HTC HD2 phone, i can easily get another screen but require assitance in replacing it??? could you help?
HTC might help you with this because it is so new. However if you dropped it (etc.) and if HTC doesn't replace it for you, You can get the part at HTC HD2 Repair and there is a guide that shows you how to put in the part at HTC Repair Guide.
Apr 03, 2010 | HTC HD2 Smartphone
HTC Touch HD Smartphone Logo
129 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
