Question about Watches
I don't understand what sig or spl mean or how to use them
If you go to the alarm part what does the SIG stand for
The SIG means HOURLY SIGNAL and if it is ON,means that every hour (0900,1000,1100 etc.) the alarm beeps twice and stops.You can set to OFF as well.
May 06, 2013 | Casio AW80-7AV Wrist Watch
Can't disable the alarm, the alarm goes off at 11pm every night and i want to disable it so that it no longer chimes at that hour. what do i do?
Press lower left hand button until you reach alarms may say snz or sig use the bottom right hand button to cycle through the options, to turn an alarm on or off press the adjust button top left you will then see off or on in the lower circle on the watch face. Also there is a graphical display at the top of the screen Alm sig and snz when there is no black bar here all alarms are off.
Dec 21, 2009 | Casio G-Shock G701D-2AV Wrist Watch
Need to learn to make adjustment on my watch
Setting CASIO G-Shock Watch
1) Home City
2) Home city and Setting the digital time
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
( ) Button reference
C__ D
1) Select home city first (if equiped):
Press C until regular timekeeping mode is reached. Hold A until seconds flash. Press C to get to city code. Use B and D to move city east or west to your home city. Press A to set and exit.
Press C until timekeeping mode is reached. (makes higher pitched beep)
2) Set time, Date, etc:
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A to exit.
4) Alarm set/on/off
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B or D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off. Repeat for AL2 - AL4. Press C to return to Timekeeping mode.
To stop any alarm, press any button.
5) Snooze (SNZ):
Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B or D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To cancel the next snooze: Press C until the timekeeping screen is reached or go to the Snooze alarm (SNZ) screen.
6) Hourly Chime (SIG):
Press D to select hourly chime (SIG). Press A to toggle chime on and off.
May 11, 2009 | Watches
I can't turn the alarms off on my Casio GW-330ca
Setting CASIO G-Shock Watch 1) Home City
3) Adjusting hands
4) Alarm set/on/off 5) Snooze 6) Hourly Chime A --- B ( ) Button reference C __ D
Hold A until seconds flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
3) Adjust hands (if equiped):
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to go back to timekeeping mode.
In Timekeeping mode B is illumination and D is time/day/date display advance.
4) Alarm set/on/off
5) Snooze (SNZ) Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off. Press C to return to Timekeeping mode.
To stop any alarm, press any button. To cancel next snooze, Press C and go to either the timekeeping screen or the snooze alarm screen.
6) Hourly Chime (SIG): Press C until alarm mode is reached (AL1 - AL4 + SNZ and SIG).
May 09, 2009 | Casio G-Shock G2600 watch
I have the wrong day of the week, when I set the date.
The day of the week will be right after setting the year, month, and date. Adjust with step 2) from timekeeping mode (where time, date, and day can be toggled with button D).
1) Home City
2) Setting the digital time
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A --- B
C __ D
Press C until timekeeping mode is reached (high beep).
Press C until H-Set is reached. Hold A until time flashes. Press D to advance minute hand. Press B while holding D to set faster and continuously. Press D to stop hands when correct analog time is reached. Press A to exit H-Set mode. Press C to return to timekeeping mode.
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 27, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
I cant set the digital time in casio illuminator
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Apr 16, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock alarm not working
The alarm should be sounding. (broken?) To turn hourly chime on and off, go to alarm screen and select SIG. Then top left button turns it on and off.
A -- B
C __D
Good luck,
Techjoel
Feb 04, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Casio G-Shock 7510
1) Home City
A --- B 2) Home city and Setting the digital time
( ) 3) Adjusting hands
C __ D 4) Alarm set/on/off
5) Snooze
6) Chime
Hold A until second flash. Press C until item to adjust is flashing. Press B or D to adjust. Press C to go to next item. Press B or D to adjust. Press A when done adjusting all items to exit.
4) Alarm set/on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select alarm to adjust. Hold A until alarm time flashes. Press B and D to adjust alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn alarm on and off.
5) Snooze (SNZ) and Hourly Chime (SIG):
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select snooze alarm (SNZ). Hold A until snooze alarm time flashes. Press B and D to adjust snooze alarm time. Press C to toggle between hour and minutes set. Press A to exit. Press A to turn snooze alarm on and off.
To turn any alarm off, press any button. To cancel next snooze, Press C to go to either the timekeeping screen or the snooze alarm screen.
6) Chime on/off
Press C to enter alarm mode (AL1 - AL4 + SNZ and SIG). Press D to select hourly chime (SIG). Press A to toggle chime on and off.
Good luck,
Techjoel
Nov 18, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Watch
1) Home City
3) Adjusting hands
4) Alarm set/on/off
5) Snooze
6) Hourly Chime
A -- B
C __ D
4) Alarm set/on/off
5) Snooze (SNZ):
Good luck,
Techjoel
Aug 08, 2008 | Casio G-Shock G510D-1AV Wrist Watch
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
