Question about Kitchen Ranges
I have a SteamVac - widepath LS purchased 12 amps five+ years ago with no instructions. The model # is F6040-900. Can you help. Thanks
  • sfettus Sep 04, 2010
    terrific! thanks
    this solution is exactly what I wanted thanks
    Brigadier General:
  • 7,191 Answers
You can download and print the instruction manual in PDF format by clicking this link
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Please let me know if you have any difficulty in downloading the instructions.
Kindly rate and accept the solution if it helps you. Thanks for using FixYa.
Posted on Sep 03, 2010
Attach the hose to a "hoover f7425 900 steamvac v2 widepath
click here> http://hoover.com/file/670/ for the manual it will give you full instructions how to attach the hose
Sep 25, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
I have a Model F7431-900 and is a SteamVac V2. When I press the trigger for water or cleaning solution, the water just runs right through it even after releasing the trigger. What kind of problem do I...
This sounds like a stuck solenoid. The Dual V models use solenoids to contol soap and water flow to the floor, along with a pump unit. If your unit is 12 months or less it is under warranty. I am not sure about the cost of the solenoid.
Apr 14, 2010 | Hoover SteamVac V2 6-Brush Widepath...
Burning smells from the bottom on my SteamVac Widepath LS. How can I open it to check the belt? do you have a diagram? Thanks
that model doesnt have a belt, it has a gearbox that runs the brushes. if you are getting a burning smell its probably the motor going bad. how old is the machine? i can give you a diagram if you want to attempt to replace the motor or would just like to have it. Let me know and ill upload it to my adrive account and give you the link.
Jan 05, 2010 | Hoover STEAMVAC VACUUM Vacuum
The scrub brushes dont spin anymore
The brushes are turning by an air driven turbine. The turbine has a pivot bushing made of steel inside of it that gets rusty because of the water that is running through it. The turbine gear will have to be replaced. You can access the turbine gear by removing the hood. You can find a genuine hoover replacement part by following the link below. Just find the model number of your Steamvac.
http://www.usavacuum.com/Hoover-SteamVac-Parts-s/105.htm
Oct 23, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Need manual for ultra steam shark model #EP903SH
If this is a Hoover Model, Go to Hoover Website you should be able to download manual from there !
Sep 19, 2009 | Hoover F6030-900 SteamVac WidePath Wet/Dry...
Hoover widepath steamvac
One cause is the filter in the dirty water tank lid is pushed up too high, it needs to have a gap of 1/4 in or so. So check it, if it is up all the way, pull it down some.
Jan 15, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Hoover Steamvac Widepath 6500 leaks
You didn't give your model number, but if this is a V2, you may have a crack in the tank, alot of times it is underneath the seal on the bottom. Or the plunger at the bottom of the tank is stuck open or missing.
Dec 02, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Brushes are not moving
You should be able to get a manual from Hoover.
Oct 21, 2007 | Hoover F7425-900 SteamVac V2 Widepath...
Kitchen Ranges Logo
54 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
