Iriver H10 20gb will not power on. It was accidentally plug into a motorola cell phone charger. It will charge with the home charger, but not the usb charger.
Its not usable anymore you might have to get a new one,besides iriver sucks *** anyway..
Posted on May 11, 2008
My motorola Blur won't charge, I've tried other chargers and nothing, it will catch a charge for a second and then nothing, now my phone is dead
My Motorola Blur would not charge kept saying Connect Charger. I tried various power connecters including the Original one that came with the phone and the USB to no avail. This morning I took the phone apart and clean it and still would not recognize the charger.
Fix: I lifted up the connector where the charger plugs into on the actual phone and now it is making contact and appears to now be charging my phone.
Sep 15, 2011 | Motorola Mobility CLIQ Cell Phone
Motorola A1200 cell phone battery will not charge with AC chargers
HI,
If your phone is still under warranty the best solution is to get it replaced.The problem is actually with the port of the charger.I mean the hole in which you plug in your charger isn't working properly.Where as your USB port is different and works properly so it charges the battery.So you will have to get this repaired.
Sep 18, 2008 | Motorola Mobility A1200
I have a motorola L6i. Left the charger at home and need to charge to phone. I tried plugging it in with a usb cable I have to the computer however still will not charge. I understand I have to download...
You shouldn't need the driver to charge the phone, just make sure the USB port is powered. But, you can download the driver here: http://www.nodevice.com/driver/L6i/get39381.html
Mar 25, 2011 | Cell Phones
My phone is not charging up when I plug it into the charger
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Secend Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Aug 17, 2010 | Motorola Mobility C118 Cellular Phone
"Black screen of death" iriver H10 6GB color
sounds like incorrect charging voltage and amperage may have fried some of your components.
Could try selling it on ebay as-is to make some money toward another unit.
You can get a top notch 20gb refurb unit from ebay sellers (like metromania) for $40-60. I have 2 refurbs and 1 built from parts from as-is units.
Mar 07, 2009 | iRiver H10 MP3 Player
Home Charger Quit Working
Hi!
Its not due to charging it via usb. Your charger is not giving full amount of charge and thats why its charging with the usb but not with the charger. And, if that is not the case then somehow an internal ic inside your phone is blown and needs a repair.
Please ask for further clarifications.
Please rate this solution as FixYa if found useful.
Thanks
Rylee
Mar 01, 2009 | Motorola Mobility RAZR V3
Motorola RAZR2 V9 new phone wont charge
Spare Battery Charger - Motorola RAZR V8 /V9 - $14.95
will need also a USA/Uk power adaptor /converter to use in Uk.100% works by charging battery separately from mobile
Jan 29, 2009 | AT&T Motorola RAZR2 V9 Cell Phone - Purple
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Does leaving a cell phone charger plugged in to an outlet at home,without having the phone charging in it,drain energy from your home?
Yes. You are right. Here energy is not the criteria. It is always safe to unplug the charger (when not in use) to prevent the damage of a cell phone due to accidental over load of electricity or short circuits. Moreover Chargers do draw power when plugged in, whether or not a device is actually being charged.
If the charger is plugged in someplace easy to access, like right by where you keep your phone, you should unplug it. But if it would be difficult to have to plug it in every time you need to use it, you'll be fine just leaving it plugged in..and.It still uses energy even when not charging. Any electronic device plugged in a socket uses energy whether it is in use or not.
Oct 07, 2008 | Samsung SGH-D900 Cellular Phone
Motorola RAZR V3
Install Motorola Phone tools first,it contains all drivers for all Motorola phones,plug the cable and charge
Sep 16, 2008 | Motorola Mobility RAZR V3
66 people viewed this question
 Grubhead
Grubhead
