Question about Dryers
Heat comes on sometimes but not always. How do I check the spark starter tosee if it has moved or out of alignment?
  • 4,323 Answers
Hi
If your dryer is not heating, then check if the power cord is plugged into the wall. It may be loose or disconnected. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working. Now, check whether the heating element in your gas dryer is burned out by using an ohm meter to check for continuity. If the continuity is not there then you would need to replace the element. After checking the element, check out the thermal fuse to see if it's burned out. The thermal fuse is attached to the exhaust duct on the back panel of the gas dryer. It's usually surrounded by a black resin material situated in a housing made of white plastic. If the fuse looks like it's blown, then it needs to be replaced.
Now, check the igniter, there is a plastic connector attaching the igniter to the burner. Disconnect this and place the probes onto the two contacts of the igniter. The meter should read under 100 Ohms of resistance. If the reading is above 100 ohms then igniter is bad. If the igniter passes the test then you need to test continuity on the flame sensor. You should have continuity between the two contacts. If not, then you need to replace the flame sensor. The sensors are usually located close by the igniter so are easily visible. Hope this helps...
Daniel
Posted on Sep 04, 2010
Why does my car start most of the time,but not all the time?
Are you sure it has spark, next time no start condition happens try spraying some starter fluid in throttle body and see if it starts.
I say this because if your fuel pump is weak and failing the jiggling of the car when you move it could cause a weak pump to work.
press the helpful button and check link below
1998 Lincoln Town Car Fuel Pump Replacement
Jan 16, 2016 | 1993 Lincoln Continental
How do i change the starter
3 bolts hold and align starter with the flywheel of your transmission...be sure to disconnect a battery terminal first to eliminate sparks...starter/solenoid is one piece, try looking at one at your auto parts store first...Hope this helps.
Oct 07, 2015 | 1995 Cadillac DeVille
Intermitten Shift Problem
There is a release which is suppose to allow for the shifting of gears only when your foot is on the Brake. The switch is on the brake pedal lever and is suppose to be aligned so that the starter solenoid, the gearshift, and the Ignition switch are aligned.
Some manufacturers protect against lurching by preventing starter engagement, some by requiring a foot on the brake pedal, and some do both.
As for being intermittent, the switch may be loose, the Ignition switch misaligned, or the shift cable stretched. Sometimes with a Tilt wheel, the alignment flexes.
Please rate my info.
Mar 05, 2013 | 2006 Ford Escape
Need help in putting the starter back on a 1999 cougar
check the alignment of the starter sometimes they need shimmed check your flywheel for any issues they will come loose and sometimes they will crack
Jul 07, 2012 | 1999 Mercury Cougar
1982 Pontiac Firebird Trans Am, starter solenoid only engages sometimes (starter motor always spins), occasionally starter gets stuck ON, and sometimes no spark (fuel is fine but car won't start u
ANY FAULT CODES? HAVE YOU CHECKED THE STARTE DEPTH FOR PROPER CLEARANCE? HAVE YOU RITIATED THE FLYWHEEL TO LOOK FOR MISSING TEETH? I HAD AN 82 T/A AND THAT WAS WHAT CAUSED MY STARTER PROBLEMS. AS FAR AS NO SPARK DO YOU HAVE ANY FAULT CODES INTHE ELECTRONICS? TO TEST WITHOUT A SCNNER GO TO THIS LINK
Feb 11, 2012 | Cars & Trucks
Willnotstart
WHAT DO YOU MEAN , DOES IT TURN OVER, IF SO CHECK TOSEE IF YOU HAVE SPARK AT THE PLUGS IF YOU DO THEN CHECK THE FUEL PRESSURE IF YOU HAVE FUEL PRESSURE . CHECK THE FUEL INJECTERS WITH A NOYED LIGHT TO SEE IF THEY HAVE A CURRENT FLOW OR ELECTRIC.IF IT DON'T TURN OVER CHECK BATTERY, OR BATTERY CONECTIONS OR STARTER.
Dec 20, 2010 | 1994 Ford Explorer Limited
I HAVE A 97 F250 7.3 DIESEL. THE STARTER IS NEW BUT WHEN I TRY TO START IT IT SOUNDS LIKE THE STARTER IS KICKING IN AND TURNING BUT THE MOTOR IS NOT TURNING. WOULD THE GLOWPLUG RELAY CAUSE THIS?
Don't think so. It sounds like the starter is mis-aligned and not engaging the flywheel. When the starter spins, the gear on the end is supposed to move out and engage the flywheel. Sometimes the springs are bad or there is too much friction on the spiral shaft, but if this is a new starter, more than likely it is mis-aligned.
Sep 06, 2010 | 1997 Ford F250 SuperCab
Not always starting
having start problems. It will start when battery is fully charged. If not have to go under the car to spark a start. What do i need to get it going right again. John
Apr 30, 2009 | 1991 Buick Century
Mower will not start
Hi
Take the spark plug out and pour a little bit of oil in the cylinder and crank it over without the spark plug in. Make sure ground wire is clean on both ends.
Apr 13, 2009 | Garden
Dryers Logo
Top Dryers Experts
