Question about Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000
How to change sanding discs? - Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000
    Problem Solver:
  • 5 Answers
I believe these are the hook and loop variety, similar to velcro, just pull off the old and place new ones on your sander. If you do not have the hoop and loop, and they are sticky back, you have the wrong discs.
Posted on Sep 05, 2010
Change a disc on the 5" sander on the belt and disc sander item 10027
please be more specific!!
guessing - bench top disc/belt sanders' discs usually use stick on backed sand paper discs ;)
Jan 13, 2015 | Sander Tools & Hardware - Others
How to replace the sanding belt
Google the model number and "manual".
Mar 24, 2014 | Rockwell RK7866 Belt Disc Sander
Removing the disc sander on an erbauer erb050bts to replace the belt
The drive belt is a toothed rubber belt, which will be 'thrown off' if there is too much resistance to rotation (pressing too hard, or sanding belt not correctly aligned and rubbing against the side).
To access this, it is not necessary to remove the sanding disc.
Remove the two allen bolts on the top which hold the disc belt assembly (NOT the one that clamps the belt drive disc). The whole assembly lifts off, giving access to the drive belt. It is a bit fiddly, but it can be hooked back on the pulleys and the bolts refitted. Good luck!
Dec 11, 2012 | Tools & Hardware - Others
Sander disc no longer "sticks"
Most commercially made disc sanders have replacements pads whether they are hook and loop type or the rubber. If you go to the manufactures web sit and look up your sander, it will usually be listed somewhere. But you might have to call an authorized repair center to find the part number to order.
Jun 07, 2011 | Vacuums
NEED NEW VELCRO DISC PAD SANDING DISC WAN`T STICK
http://www.hitachi-powertools.co.uk/locator.html
This will take you to the UK dealer locator. If you are outside the UK you will find tabs at the top of the page to direct oyu to other regional sites.
Jun 13, 2010 | Hitachi SV13YB 5" Random Orbit Finishing...
New 4" angle grinder does not come with sanding disc pad
You need the 4" rubber pad, Makita Part #743009-6. It can be found on websites like www.ereplacementparts.com.
May 23, 2010 | Makita 9553NB 4" Angle Grinder
Cant figure out how to install the sanding disc's
This info may help;
Features: DeWalt D26451K 5" Random Orbit Sander Kit
  • 3.0 Amp motor operates at 12,000 opm providing ideal sanding speed for smooth finish
  • Textured anti-slip top & body grip provides ultimate comfort and control during prolonged use
  • Controlled Finishing System maintains pad speed and minimizes gouging during start up
  • Dust-sealed switch prevents contamination
  • Sealed 100 percent ball-bearing construction provides longer life
  • High capacity dust bag with built in vacuum adapter provides maximum dust collection with or without vacuum
  • Dual-plane counter-balanced fan reduces user fatigue
  • Accepts 5", 8-hole hook & loop paper allows sanding discs to be switched back and forth quickly and easily
  • The sanding discs mate to the sander plate similar to Velcro, and this particular sander uses a 5" disc with 8 holes in it. Can be purchased in Home Depot, Lowes, etc....
Hope this helps!
Jul 23, 2009 | Dewalt d26451k 5" random orbit sander kit...
Sanding Belt Slips Badly
Check and see if the pulleys on the sander are not glazed this somtimes will cause the belt to slip. Give them a good cleaning. If this does not help there is a good chance the spring on the belt tensioner is weak and need changed.
Hop this helps
Jan 09, 2009 | Tools & Hardware - Others
Bosch 6" 60-120-240 Grit Sanding Discs for Wood (6 Pack) SR6R000 Logo
57 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
