Question about Bushnell ® HOLOsight
Holosight will not turn on. Replaced batteries with known good batteries and batteries are in the correct position. (Sight was working, opened battery compartment to replace with fresh batteries for a shooting match and sight no longer worked.)
2 Suggested Answers
  • 2418 Answers
SOURCE: I put fresh batteries in
Check that the batteries are in right side up.
Posted on Mar 09, 2011
Need batteries for my Bushnell holo sight
I use energizer E9 in my Holosight gen 1.
Mar 17, 2014 | Bushnell ® HOLOsight
Turn of bushnell holographic sight
this would depend on the model but most likely pushing the up and down buttons for brightness at the same time.
Nov 30, 2013 | Bushnell ® HOLOsight
Holosight dim in bright sunlight
I would send it to them to be checked.
Bushnell
Attn repair
9200 cody
overland park KS 66214
make sure to put your name, address, telephone number, and a detailed description of the issue in the package.
Feb 13, 2013 | Bushnell ® HOLOsight
Bushnell holosight battery goes dead after only 20 or 30 min. Mfg. date: Feb. 2008 no. 392811
Make sure the battery you install is fresh and at full rated voltage. Even recently store bought batteries can be questionable. This will require a test meter; if you don't already have one, Tool King has battery testers for a couple bucks and digital multimeters for $10; good to have around. If this is too much of a challenge, can a friend help? Otherwise, this sounds like the battery is being shorted out. First, remove the battery and make sure the contacts are not bent, causing them to touch together. Examine the compartment it sits in for debris, corrosion, or any other contamination. If you see something, determine whether you can safely remove it without causing damage. If there is corrosion you might be able to clean it up by using a cotton swab(O-Tip) and rubbing alcohol. Otherwise, send it back to Bushnell with a description of the problem. Be as accurate as possible, including the circumstances under which it occurs. Include your name, address, and a number where you can be reached. They'll take it from there. They may call you if they have any further questions, and, if you feel the sight failed without reason(dropping it, soaking it with cleaning solution or lubricant, etc) let them know, and they may repair/replace it under warranty. Sometimes companies experience problems because of poor design, bad manufacturing or componentry that fails prematurely.
Nov 30, 2010 | Bushnell ® HOLOsight
Batteries for a bushnell holo sight 1998
Energizer E 90,2 batteries. Thats for the gen 1 holosight.
Oct 28, 2010 | Bushnell ® HOLOsight
Sighting the Bushnell Holo Sight
here is were you can download the manual
http://www.retrevo.com/support/Bushnell-51-0021-manual/id/8328bh538/t/2/
Jul 19, 2009 | Bushnell ® HOLOsight
Bushnell holo sight
It will test the condition of the batteries. Turn the sight on to its brightest setting and leave it for 2-3 minutes. Then while looking at the red dot, press the battry icon button and hold it in. If the image does nothing, you are good to go. If it starts flashing, then you have less than 20% left in the batteries.
Jan 13, 2009 | Bushnell ® HOLOsight
Bushnell Holosight short battery life, batteries hot
This sounds like a short. Send the unit for factory service!
Jerry G.
Mar 16, 2008 | Optics
Bushnell ® HOLOsight Logo
105 people viewed this question
Top Bushnell Optics Experts
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
