Question about Bulova Watch
Have Citizen watch 2500-S76418 WSB 39042 How do I remove back to replace battery? What battery does it call for.
Hello I've had my citizen Eco drive skyhawk watch for at least ten years now. I remember reading in my manual years ago that a battery needed to be replaced even though it's solar powered. My watch went...
There could be other issues beside the battery. My best solution would be to take back to where you bought the watch, or any other authorized Citizen watch retailer for repair.
This is Citizens web site:
http://www.citizenwatches.com.au/
Best regards,
Mar 16, 2011 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Have fitted a new battery but no joy, any tips I can try?
mcdevito75 here, Some quartz watches and I believe Citizen is on of which need the exact factory number battery installed / replaced. if you did use the exact battery number and the new battery is not working, remove the battery and carefully clean the battery contacts with a Q-tip and rubbibg alchohol do not soak the battery contacts just clean them. Also your new battery could be dead, who knows how long it was on the store shelf. Alaso wipe off any oil from your fingers on the new battery before you install it in the watch, make sure the battery is seated correctly in the watch, the back cover may also have to be installed back onto the watch to complete the battery circut for the watch to work. If all this fails you can try to contact Citizen online, Contact CitizenWatch.com and get their recommended battery size for your watch, OR, look for a small watch repair shop in your area. One Last thing, Your Citizen watches Quartz mechanism could also have gone bad, in this case you"ll need a new watch.
Feb 11, 2011 | Citizen Watches
My watch has stopped
Hi.
Go to a shop and ask to replace the battery.
Even if the battery can be replaced at home, using tweezers to remove the back plate, replacement must be done by a technician at the shop. If you have not done this operation before, it is very easy to mount the seal incorrectly, compromizing the watch integrity.
Regards.
Apr 08, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
Citizen solar watch will not keep time if removed from light
If your watch is light powered, it does not have battery. However, there is a capacitor which needs replacement. New capacitor usually revokes light powered watches and makes them work as new. Rate me,plz.
Feb 02, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
Hi i have a citizen 100m chronograph watch and i have broken the stem trying to replace the battey how do i repair it or do i have to take it to be repaired.thanks karen
You have to take it to your nearest Citizen dealer, as you won't be able to replace stem yourself. Note: You do not need to remove or to do anything with the stem for replacing battery.
Jan 24, 2010 | Citizen Eco-Drive BL006056H Wrist Watch
My citizen watch number came out from dial. Please
To gain access to the face of a watch removing it from its case and is best left to a professional, since there can be unexpected difficulties.
Replacing the back seems to cause difficulties since care is needed to maintain the moisture seal.
Dec 24, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
How do I know if a citizen watch I have is fake
check the case back if the case back dosn't say citizen its a fake
Jul 12, 2009 | Citizen Palidoro Diamond Watch for Women
No jewelry store can get the back of my citizens watch of for a new battery
http://www.hurleyrobertsservice.com/v2/web/index.php
Here is the link to Citizen Authorized service centers, I am sure they can open the watch. Sometimes it is just a matter of having the right tool. I have several Citizen watches that are not supposed to be opened by anyone other than citizen. Good luck and I hope that helps.,
May 27, 2009 | Citizen Mens Stiletto Eco-Drive Watch
Citizen eco drive cell installation
a customer came with a eco drive watch dead. i opened the back and removed the battery. the battery was totally dead i fixed back and kept the watch in sunlight for an hour still it did not work. what could be the reason?
Oct 31, 2007 | Citizen Eco-Drive Silhouette EW869452D...
Bulova Watch Logo
336 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
