Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printing My Epson DX is not printing as it should. All the ink cartridges are full but the print is coming out with some lines only half printed.
  • blizzard24 Jun 08, 2008
    i have the same problem, all ink is full but printing with blank spaces in between the text.
    Novelist:
    Scholar:
  • 125 Answers
I would venture a guess that probably you both had the cartridge refilled. That is probably why there is air inside the cartridge. In effect a tiny air bubble acts like an air dam. You can try doing a lot of nozzle cleaning. There is a chance it flush out the air. Since is doing partial printing, chances are the bubble is not inside the printhead. So hopefully the flushing should solve both your problems. If it doesn't I'll refer you to a site where you can see the video of how to flush out the air. Also make sure you turn off your printer on the printer's power switch and not the AVR or power strip. This is sometime a cause for the blockage and sometimes it is also causes ink to dry up on the print head causing another kind of blockage.
Posted on Aug 01, 2008
My epson xp-435 keep running out of ink after half a dozen prints. My ink just doesn't last and we always buy epson ink cartridges.Its costing us a fortune in ink. Jose.
Check your settings. If you are printing photos and are printing them as glossy you will go through ink quickly. If your just printing text documents look at your menu on the printer to look for an eco mode that uses less ink.
Jan 19, 2017 | Epson Office Equipment & Supplies
Prints half page
Printing half a page with an Inkjet machine is not normally a computer issue. So windows 10 would not normally have any effect on the printing for a printer that has been accepted by the Windows 10 Operating System. If there was an issue in the software it would be printing gibberish or not printing at all.
Printing half a page is quite possably something stuck in the printer stopping the ink from getting to that half a page if it is printing down once side but not the other.
Printing half a page being that the top half is printed but not the bottom half (Or the other way around) it could be an air bubble in the feed line which can be cleared with a printhead clean or two.
Printing half a line rather than a full line such as the top half of each letter is clear but the bottom half of each letter is not visable is a blocked printhead. A couple of printhead cleans can also fix this.
Also check to see if the printer is not confused and actually has empty cartridges even if the printer thinks they are full. Brother printers can easily get confused about ink levels. If the cartridges are actually empty, replace them and away it should go again.
Hope that helps
Mar 09, 2016 | Brother MFC-490cw All-In-One Inkjet...
My epson stylus DX 5000 prints out with half the lines of the document missing. It's OK for a couple of lines, then odd single lines and half line are missing. I't has full ink cartridges and ve tried the...
I would go to the epson website and download the latest driver for the printer. More comprehensive printing sofware might require the PCL version of the driver. But for regular printing, just download the latest PS driver and see if that helps
Mar 02, 2011 | Office Equipment & Supplies
The printer is only printing in two colors and only in lines going across the page. not a full print
Make sure that the ink you have, is Epson Ink.
I bought a compatible, supposely ink, and when I put it in, Colors did not come out the same. Lines and words, did not print out properly.
So I threw the ink cartridges, and bought original, Epson Ink, and Ooh-LA-LA, Printed out just fine.
Go Figure.
Good Luck
Nov 03, 2009 | Epson Stylus CX5000 InkJet Photo Printer
I changed the black ink cartridge and the printer
Calibrate your new blank ink cartridge, have some nozzle check, cleaning check, and printer alignment. This are procedure that new ink cartridge will have to calibrate before you use. Epson printer are very sensitive when capable of changing ink cartridge. Unlink HP directly work without any print test because the cartridge head and ink join together, Epson with ink cartridge and the head separate.
Have some test on it at Printer Maintenance.
I'm sure 100% works on it.
Sep 23, 2009 | Office Equipment & Supplies
Draining the ink!
Printing photos with Epson drains the cartridges alot faster than printing documents. The dpi settings for photos are much higher to get the photo quality. Blue is a base color that helps to mix to create some of the colors in the photos so this is normal with the Epson brand. Hope this helps.
Dec 24, 2008 | Office Equipment & Supplies
Not printing properly
My printer epson D88 is not printing all the lines clearly, some lines, about 10% look as though they have been ''rubbed out'' (partially erased) are you able to offer a solution please?
May 27, 2008 | Epson Stylus D88 InkJet Photo Printer
Ink
Epson ink jet printers require all of the ink cartridges to have ink in them in order to print any color, black and white, or grayscale images. Epson printers contain a permanent print head that needs to be charged with all colors to work. Even when users are printing black text only, a small amount of color ink is used to keep the print head charged for color printing and prevent air bubbles from entering the color print nozzles which can damage the print head. Therefore, once one of the cartridges are expended, the printer signals you to replace the cartridge in order for printing to continue.
May 19, 2008 | Epson R245 InkJet Photo Printer
No ink coming from cartridges.
Seems like a lot of people are all of a sudden having these problems. I have had this printer for 4 years I think and no problems at all. Phone support says to clean the heads 3 times and then they give up. By the way, there is no tape to remove from authentic ink cartridges for this printer. The cartridge holder pops a hole in the film. You cant pull that cover off, it is popped when inserted.
Jan 28, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Epson Printer - Skipping When Printing Black
If you try the print head alignment or head cleaning wizard under the maintenance tab, they may help!
Dec 18, 2007 | Epson Stylus CX3810 All-In-One InkJet...
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
85 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
