Question about Toshiba Satellite M35X-S161 Notebook
Toshiba laptop question
Hi there, i was looking into buying a used toshiba satellite m35x and wondered if you found any solution to your problem, or at least a good diagnosis, as the laptop i am looking at seems to have a similar problem. thanks!
  • AlexCn Dec 08, 2008
    I have a Toshiba notebook Serial number 16194222Q
    Model Satellite A105-S1013 purchased Feb 2006.
    About 3 months ago I updated the BIOS to what I believe is still the latest BIOS -- Version 2.20 03-15-2007
    Running XP home with SP3 and likely all current updates, including what I believe is the latest optional update to synaptic touchpad software, version 6.2.
    Note that I have two different users that log on, myself and my wife. I use it 98% of the time.
    ABOUT a month ago, if I remember right, SOMEtimes when I started up from a cold start at the login screen (where I chose either to login as Alex (me) or as the wife the cursor would be briefly live and then freeze (would not respond to the touchpad). If I used the keyboard (tab key) to navigate to the login I could proceed and the computer would be fully functional (at least to the extent of anything I could run by using keyboard shortjust) but cursor still frozen.
    Other times the cursor will not freeze prior to login, but about 15 seconds after logging into Alex (my desktop) while the appletts in the system tray are loading it would lock up. I began to suspect that something loading in the system tray was locking it up and started disabling them. Thought I had found the guilty applett when I disabled Windows Defender, but that turned out to be not so. Other reason I thought it could be something loading in configsys startup is in the next paragraph (because wife's login has different configsys list.)
    When the cursor is frozen the icon for synaptics touchpad in the system tray has a red X on it.
    And here's what I think is the both the clue and the real kicker:
    If the cursor is completely locked up on my login and I use Cntrl-Alt-Del to get the Task Manager and then Alt-U to get the shutdown dialog and then use Log-off Alex (or Switch user) to get to my wife's login, THEN the cursor is fully functional. If I switch back to my side it's still frozen.
    Again, this might suggest there's something in my startup that's the problem, EXCEPT that SOMEtimes I still get a frozen cursor before logging into either user. Also, my startup really doesn't have anything new or updated that wasn't there before this freezing started as best I can tell. The newest thing was Windows Defender IIRR.
    Other item of info:
    If I luck out and AM able to log onto my own user without the cursor freezing if I hibernate the computer (rather than shutdown and restart) it stays unfrozen forever. In other words, if it gets past the login and the loading of my settings without freezing it's free and clear.
    Again, I would suspect something in the startup list on my side EXCEPT that SOMEtimes it freezes before even logging in to my side.
    Clearly this is not a hardware problem.
My cursor is frozen in the middle of my screen. How do I locate the button to enable it again?
Posted on May 30, 2008
I have Toshiba M35X satellite series. The problem is my laptop starts being late after it is turned on. And the other problem is the battery can be charged only up to 52%. After that the laptop will urned...
First, this may be an issue of old battery. The m35 is a rather old model, so it's no wonder if the battery fails to load at all. Second, your laptop may be suffering from the Maxim chip problem. During the time of m35, a lot of other laptops had this same problem with this Maxim chip that caused all kinds of weird problems with both Toshiba and HP models such as the m30, m35, m115, A65, A75 etc, and the HP NC6000, NC7000 and NC9000 series. It's a long story, a long explanation on how to repair the dead Toshiba m35 laptop. Take a look at the post for symptoms and solution, and don't forget to leave a comment if you find it helpful.
May 20, 2010 | Toshiba Satellite M35X-S163 Notebook
I was wondering the part number for the hard drive
Are you replacing it? Find the part at Toshiba/support - search your model and check the specs.
Or
Act like you are buying one from them and they will give it to you that way.
a
Oct 01, 2009 | Toshiba Satellite M35X-S149 Notebook
Is good to buy a refurbesh Toshiba Satellite M35X-S109Pc
That depends.
If the battery holds a good charge and it comes with documentation and more importantly at least 90 days warranty then yes it probable is worth buying a refurb. Mose so if the refurb was don't by Toshiba or an AUTHORISED Toshiba agent.
Aug 17, 2009 | Toshiba Satellite M35X-S109 Notebook
Compatible Toshiba System Boards?
Hi Ray !
I would not risk to buy on-line system boards for two reasons!
ONLY when you get it, you will know if it FITS in the chasis, and if it WORKS after you connect all wires and parts, but i believe you'll have to pay for it before!
Try to get some help from Toshiba support first!
Also, you just mentioned the difference between two boards you have on-line, but not the price.
Did you ask Toshiba how much will cot you a new board?
If there is acceptiable difference, buy a new one !
Regards.
Apr 20, 2009 | Toshiba Satellite M35X-S149 Notebook
Replacement of 40GB HDD for Toshiba Satellite M35X-S114
Yes you can install a larger HD and if you save alot of stuff on your computer then yes it would be good to do this.
Dec 17, 2008 | Toshiba Satellite M35X-S114 Notebook
Satellite laptop turn off
Hello maurice. Looks like you have an over-heating problem. The CPU has more chance of overheating when you use graphic intensive applications like Games etc., Clogged heatsink is one of the reasons for over heating. It would require you to get to the heatsink and clean any dust or any other stuff that may have got clogged in the heatsink. Another Idea will be to buy some kind of laptop cooler like the one below.
http://www.circuitcity.com/ccd/productDetail.do?oid=89840&om_keycode=3
Sep 28, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba m35x s149
Hey i just read your post and i have the same proble with my laptop did you find any solution for the problem
Sep 13, 2008 | Toshiba Satellite M35X-S349 Notebook
Toshiba Satellite M35X-S161 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
