Question about GE JGBP40 Gas Kitchen Range
JGBP28SEM1SS LP GE Range
We are having problems with adjusting the oven / bake LP adjustment. The broiler, & the top burners all work well. The orfice that is in the bottom bake rail is a 48 - 56 - - - size and we are wondering if the actual orfice hole size is accurate to the numbers provided & what to do next. Is the orfice hole too big or too small. No matter what we try in the initial adjustments, we can not obtain a steady bluish flame. Too much yellow that has scorched the inside sides of our oven.
  • vivirogers Oct 13, 2008
    none of the "solutions" worked so far. We have tightened and untightened everything possible... we have changed the cap around, we have done everything the manual tells us to do.
    I believe the orifice for the gas valve (for the oven) is too large and there is no replacement part or a gas valve that fits there with a smaller orifice.
    This is a problem and I am really dissapointed at GE for not having a solution for it.
  • 770 Answers
Have you tighen it down until it wont turn anymore this needs to be done on a LP gas model going from Natual gas
Posted on May 11, 2008
Whirlpool WFG510S0AS2 range - stove burners work just fine, but both the oven and broiler does not stay lit. NOTE - this unit has been converted from natural gas to LP
when the lp conversion is done , it is normally just a jet size change that is done
however the air shroud has to also be adjusted to get a clean blue burn of the flame
The just jet change results in a slightly yellow flame which is incomplete burn of the gas and that creates carbon build up at the jet and burners causing partial blockage
I would suggest that you call in an accredited gas fitter to check the problem and if necessary , clean the jets and adjust the air shroud
Dec 30, 2015 | Whirlpool WFG510S0AS
I like to conver my american range v. Broiler. Giro infrared burner to lp gas
that simple, all you can do it go to place where you can buy a LP orfice and LP regulator and remove all NG orfice and regulator out and install all LP orfice and regulator you ready to go for LP..
Jun 15, 2011 | American Range Ovens
Prpane back to ng. Changed top burner apertures. Is there anything else I should do for the gas supply
The range burner orfices need to be changed to the natural gas ones. I am assuming when you say "apertures" you are talking about the burner orfices. If so then you have already changed the range burner orfices. There is also a orfice that usually needs to be replaced for the oven burner and top broiler burner (if you have a top broiler). And then there is usally a pressure adjustment required on the appliance gas regulator. This is usually adjusted by simply removing the regulator cap and turning over the spring tension plug inside and then re-installing the plug and cap.
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Recently purchased Frig. gas stove.Want to convert from natural gas to Lp.Do you remove spud and insert Lp oriface in spud then screw spud back onto line?Lp oriface is a lot smaller than oriface for...
Not really sure which model you have but when converting the over, ether bake or broil burner you tighten down the orfice cap. If you remove the burner off the oven valve you will notice that you can put a wrench on the orfice cap. Just tighten snuggly. If you over tighten you will crush the orfice under the cap.
Dec 22, 2009 | Frigidaire Ovens
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven produces soot when running, broiler ok, stove top ok
Al, you need to seat the needle valve on the bake. Remove the bottom drawer, right below the bake burner you will see the nut just below the air shutter adjustment. Turn this nut clockwise a few times, it might seem hard but just do it. Then try the bake again, you should have a nice bluel flame. Tenbears.
Dec 20, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Problem with conversion of used Whirlpool Range from NAT to LP
Take a 1/2 inch open end wrench and adjust the orifice on top of the oven gas valve.
Tighten it down until the flame is normal. Blue with white tips.
Nov 14, 2008 | Whirlpool SF325 Gas Kitchen Range
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
Lp flames to top of oven
You need to tighten down the orifice spud for the bake burner. Remove drawer in bottom of oven. Look for bottom of burner tube, where the shutter adjustment is. Right below it is the orifice spud. Usually a goldish color. Take 1/2 inch open end wrench and tighten until it stops. Do-not overtighten! Try it now. If flames are still to high, tighten a little more. Repeat if needed.
Nov 18, 2007 | Kitchen Ranges
GE JGBP40 Gas Kitchen Range Logo
230 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
