Question about Samsung VP-D361 Mini DV Digital Camcorder
"d" error issue with d error message still appears evenafter trying suggested resolution
  • chitrokor Jun 03, 2008
    My Samsung VP-D362 camcorder is only 2 years old with careful handling, shows Error D sign within 20-30 sec of switching on . I have tried with battery /adaptor source, changed cassette .
    But it continued to make buzzing sound as if the motor is struggling to rotate the cassette mechnism .
    I am really frustrated with it .
    Please advise me as soon as possible.
I had the same problem changed the tape and it just went. Now shows the annoying D error. Looks like a bin job.
Posted on Jun 06, 2008
I changed the video format on my night owl DVR and now I cannot get it to display on my tv. An error message appeared on the tv stating "resolution mismatch! change devices resolution"
hi,
maybe when you changed the video format the resolution of the screen was changed or
the new format needs another resolution.
try to change the resolution of the screen
daniel
https://www.rylwy.com/
Dec 09, 2017 | The Home Security
Hi, I have this problem with my dell inspiron N 4010 laptop. Whenever i want to play games on my laptop it either crashes down or after the game is over i get a "Optimum resolution error...
The LCD monitors and laptop monitors nowadays have a 'optimum resolution'. The monitor likes to work at a pre-defined resolution.
Games play at a resolution previously set. Usually this differs from the optimum resolution of a LCD/LED screen. Then this error message will appear.
However, crashing of the computer might happen due to other reasons.
*Defective RAM *Not-so-good VGA *Viruses
You have to make sure the above problems are not the reason for crashes.
Also try playing somewhat older games. If the problem occurs due to your VGA not supporting the new games, older games will work fine.
Try these suggestions and let us know.
Good luck, and thanks for using FixYa!
Oct 30, 2011 | Samsung Digimax 4010 Digital Camera
Message
Reduce the screen resolution to 600x480 for instance and see if the projector can handle the low res output OK. Then increase screen resolution on the PC unitl the error message appears. Try the video menu settings in the acer
Jul 17, 2010 | Acer X1230 DLP Projector
Unable to load windows got an error 0x80070057.plz help
What causes Error 0x80070057
# Windows Update simply has an issue with your "SoftwareDistribution" folder.
# This appears to be an issue with the program Netop which enters a driver entry into the enum\root\unknown key in the registry.
# You have old versions of OKI drivers installed.
To resolve this error, use one of the following methods:
Resolution Suggestion One:
# Try renaming the SoftwareDistribution folder:
Click Start, Choose Run.
In the Run box, type: services.msc
Click OK.
Right-click the Automatic Updates service.
Click Stop.
Stopping the service will take a moment.
Now rename the "SoftwareDistribution" folder:
a) Click Start, click Run, type
%systemroot%
...and then click OK.
b) Right-click the SoftwareDistribution folder, and then click Rename.
c) Type SoftwareDistribution.old and then press ENTER to rename this folder.
Now click Start, and choose Run.
Click OK.
Click Start.
Starting the service will take a moment.
NB - You will lose your update download history but this is not that important compared to not being anle to download the updates!
Now Try WU website again.
Resolution Suggestion Two:
# Customer will see error 0x800A138F when scanning for updates, but the Windows Update.log file will show error 0x80070057:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Class\
{63C35530-D3DF-11D3-8F5D-0060B0A3612B}\0000]
"ProviderName"="Danware Data A/S"
"DriverDesc"="NetOp Driver 3 ver. 7.00 (2002014)"
"DriverDate"="Jan 14 2002"
"DriverVer"="7.00 (2002014)"
"MatchingDeviceId"="danware_netop_driver3"
Both the DriverDate and DriverVer are not formatted properly
Visit http://www.netop.com/tech/download/fix/fixwinup.exe
and run this executable If you are running the Netop software.
(NB - Sadly this file has now been removed from their website.)
Resolution Suggestion Three:
# Update drivers for your OKI device:
Typically folk complain of problems with OKI B4300 drivers and OKI Page 14ex drivers installed...
Visit http://www.oki.com and update your device drivers.
Jul 17, 2010 | Toshiba Satellite A215-S4747 Notebook
QuickBooks Error Message "Run-time error '0' "
Issue appears to be related to IE8 and an Active X security issue.
One solution is to un-install Qbooks, update your runtime -- you'll find it here:
http://www.microsoft.com/downloads/details.aspx?FamilyId=7B9BA261-7A9C-43E7-9117-F673077FFB3C&displaylang=en
Then re-install Qbooks.
You may not need to go to this extreme as you can try just installing the runtime upgrade which may resolve the problem.
Another suggestion is to open up 'security' for IE8 and lower the security settings...although this resolution may have a downside...
Sep 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Message received is "Resolution Notifier best resolution is 1280*1024 notification keeps appearing on monitor and I cannot get rid of it. the picture appears fine, why does the message keep appearing?
This is similar to the "out of range" message that many flat monitors give when the resolution is maybe higher than the monitor would like.
It has given you the suggestion for a good reason. As with most monitors flat or crt it is possible to shorten the life of them if you abuse them in this way.
My suggestion is to lower your resolution to the one it offer you.
Aug 25, 2009 | NEC MultiSync LCD175VXM-BK (Black) 17" LCD...
Desktop doesn't appear on the computer.
hi there, The error 0xC0000005 is generated by an illegal "memory access violation". This can be caused by anything from faulty RAM, an incorrect/corrupt device driver, poorly written/updated software and more commonly under Windows XP Service pack 2, malware/adware installations.
i would suggest that the ram in your computer has possibly broken down over a period, may i recommend obtaining some new ram, if you go to www.crucial.com they can provide you with information that tells you which ram you have in your PC.
Jan 25, 2009 | Acer Aspire 3680 Laptop
Error Message "Communication Not Available
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
Feb 04, 2008 | Dell 810 All-In-One InkJet Printer
DVD Issue after newinstallation - Receiving error relating to decreasing color resolution
Better to use software such as Windows Media Player, or powerDVD, realplayer more for your internet mpeg type movie files.
Nov 01, 2006 | NEC 16X Multiple Format DVD+/-R/RW/DL...
Samsung VP-D361 Mini DV Digital Camcorder Logo
Top Samsung Video Cameras Experts
Tony
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
