Question about HP Laserjet M2727nf Multifunction Printer
Plugged into a surge protector can cause issues with the power supply. I unplugged from the protector and went directly to the wall outlet
Posted on Mar 04, 2015
SOURCE: scanned documents are very light
I have found that when scanning b/w documents, its helpful to start with a black and white copy, not a grayscale, pen written, or printed form a printer in grayscale mode copy, but a true black and white on the copier or fax copy. The scanner doesnt read shades of black so well and when scanning multiple page documents, my pixma tends to scan in lightly. I havent found a piece of software to do just this, batch darken what has been scanned (at least not for free). Copying before scanning is the work around. Hope this helps everyone who's had this problem. It also doesnt hurt to darken what your scanning down a notch when copying
Posted on Jan 30, 2009
SOURCE: Brother HL 1440 Printer Density Adjustment
Go to Printer and Faxes and select the properties button, then select the maximum dpi in the Advanced tab. You will get the best quality Print
Posted on Feb 08, 2008
SOURCE: There are verticle lines when faxing, copying, and scanning.
This print defect can be caused by a foreign object or substance on the outside of the scanner assembly, usually located on the plastic cover that the paper passes over.
Posted on Feb 04, 2009
SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
Posted on Nov 11, 2009
SOURCE: poor black print quality - printing is light and
Hi... When you are going to print, do visit the properties of the printer first. Make sure you have the 'print in grayscale' off. Hope this helps...
Posted on Feb 03, 2010
Nov 17, 2014 | Canon Pixma MX410 All-In-One Printer
Aug 07, 2013 | Canon MP Navigator EX for Windows
Apr 04, 2013 | Canon MF6530 Black and White Copier
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Apr 08, 2010 | Dell Photo 964 All-In-One InkJet Printer
Mar 09, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Nov 15, 2009 | Office Equipment & Supplies
Feb 09, 2009 | Brother MFC-7420 Printer
Dec 09, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Aug 25, 2006 | HP OfficeJet 4255 All-In-One InkJet...
771 people viewed this question
dannidewoody, i m using photoshop to darken my Scanned documents (which are actually photocopies) but when i print the scanned document it turns out fade. Please suggest
