Question about Maytag Atlantis MDE7400AY Electric Dryer
I have a Maytag Atlantis dryer MDE7460AYW. I ordered the replacement timer . Installed the New timer The dryer Now Starts and Runs but the Timer does NOT Advance and the dryer will not shut off. Any Thoughts???
  • charlesyo806 Sep 03, 2010
    Is the auto-dry sensor and the control thermostat located behind the top housing where all the controls are? The origional timer was replaced because it would not pull out and turn on anymore.
    Thanks
  • Maytag Master
  • 3,361 Answers
It would help to know why you replaced the original timer.
Otherwise,you should unplug the dryer,take your wiring diagram and re-check every wire for accuracy.
Take a volt meter after you resume power and start the dryer. Carefully touch the meter leads to the 2 timer wire leads to make sure the timer is getting power.
A bad auto-dry sensor and or a bad control thermostat will stop the timer from advancing.
Posted on Sep 03, 2010
  • steve
    steve Sep 03, 2010
    Copy and paste this Factory Service manual.
    While your model number is not listed all checks and component locations are the same as your model.
    The control thermostat is located on the blower housing..
    http://www.servicematters.com/maytag_lib...
Why doesn't the timer count down? The dryer runs & heats but the Timer doesn't move. I replaced the Timer block but nothing changed. Is this related to a bad sensor?
go bak to 4 prong. why did u change it out? souns lik this isa 220 unit and not a 110? chk the book that came with the unit. lol.
Jul 22, 2014 | Maytag Dryers
What happens when the timer goes out my maytag atlantis dryer
how do I replace the timer knob on my Magtag Atlantis Dryer MDG7400AWW
Jan 10, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Timer is not working. Can I easily fix this myself
It's not too complicated. Go to you local Maytag daeler to order your new part. Then all you have to do is remove the back cover and replace the timer.
Nov 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AYW timer has been replaced but the dryer won't stop drying on it's own. What is the reason? I have the same problem... the timer on mine doesn't seem to work. Any ideas?
The wire connections to the timer may have not been made correctly when it was replaced bypassing the OFF contact in the control circuit.  There should be a wiring diagram inside the front or back panel that you can check.
Jun 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't start when knob is pulled.
If you push the knob to the left and it makes a good contact and starts the machine, then replace the timer switch. Write down the Name and Model Number of the machine (usually on or below the door)
take it to a local appliance shop and order a new part. When you recieve the new part UNPLUG the machine and remove the three screws from of the top of the electrical compartment and gently pull o the front open, there is only one plug attached to the switch, remove it and dislodge the old switch, then snap the new switch in place and replace the plug, close the compartment and replace the three screws, plug in the dryer, and try it.
Mar 15, 2009 | Maytag Atlantis MDE6400AY Electric Dryer
Replacing Timer on Maytag Atlantis Dryer
Call a local appliance shop and ask about it. Maytag is pretty common and available. The timer will be about 75 dollars. It could be more depending on what all you have on it. It is pretty easy to replace once you get to it. Let me know how this turns out.
Jan 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Hard to start dryer, control know loose/misaligned
your saying that pulling the timer knob out, which normally starts dryer, does nothing. however if you pull out and apply pressure upwards on knob and touch nothing else, the dryer will start??? if the thats the case sounds like a short in the timer mechanism , youll need to replace the timer assy
Mar 18, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Atlantis MDE7400AY Electric Dryer Logo
160 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
