Question about Whirlpool LGQ9858PG Gas Dryer
Getting no heat in my whirlpool gold ultimate care 2 dryer
Need to know where the circut breaker or fuses are in this machine.
  • 1 more comment
  • wolf72498 May 11, 2008
    thanks i will try it
  • Anonymous Oct 04, 2008
    My Wirlpool has no heat
  • Anonymous Dec 21, 2008
    same problem also smelling gas, would fuses cause this too?
  • 770 Answers
It sounds like you blew a Thermal fuse on the heating element open the back unplug and on the right side you will see towards the top of the heating element 2 red wires check with a metter to see if good also pull the wires off the element at the bottom to check it let me know
Posted on May 11, 2008
How to replace heating element on a whirlpool gold ultimate care 2 dryer
Go to www.repairclinic.com and enter model. You will be presented with a list of common repair parts and may be able to view a video showing disassembly.
Jul 25, 2016 | Whirlpool Dryers
Whirlpool Ultimate Care II dryer trips breakers.
No way to know unless you do some checking. This video shows how to get into the machine: HERE
I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
Feb 14, 2010 | Dryers
My Whirlpool Ultimate Care II dryer does not heat up, however it does tumble. Any help would be greatly appreciated. Thanks.
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jan 02, 2010 | Whirlpool Dryers
Washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Mar 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer wont do anything after it fills
try your outlet,,plug something else there to see if you have current if so make sure breaker is 15 amps or better with washer on line alone..if good bad door switch..
Dec 25, 2008 | Indesit W 123 Front Load Washer
Whirlpool dryer will not heat properly
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Heating element
Thermal fuse
Wiring
Oct 17, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
I have whirlpool gold ultimate care 2 the dryer is heating but not getting real hot
You may be having a venting issue, disconnect the vent from the back of the dryer,if it drys normally then you have a clog in the vent line too the outside, if still takes too long too dry you may have a bad operating thermostat on the blower housing.
Jul 16, 2008 | Whirlpool Dryers
Whirlpool electric dryer will not heat
check the thermal limit on the side of the heater housing and the blower thermal on the blower housing
the emement limit is at the top of the blower housing and will have 2 red wires going to it
the blower limit will have blue wires going to it
withe the power cord unpluged, remove the wires to these two limits and with a meter on rx 1 ect. read across each of these if you do not get a meter fluctuation , all the way to the right as you check the part os bad
Apr 12, 2008 | Whirlpool GEQ9800P Electric Dryer
Whirlpool Gold Ultimate Care II: No heat
didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
Whirlpool LGQ9858PG Gas Dryer Logo
489 people viewed this question
Dan Webster
Dan Webster
Sal De
