Question about Roper Dryers
My dryer quit while drying a load of clothes, it acts as if it has no power. I have checked the brakers and replaced a fuse on the dryer but it still will no run. Any advise?
  • Roper Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Dryer wont turn on
try to spin the inner drum. You could have a broken belt. if it spins really easy, that's probably what it is. There should be some resistance when you turn it.
Sep 08, 2012 | Whirlpool Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
When drying a load of clothes the dryer (Asko 7305) simply quit and when I came back to the unit the clothes were dry, but the digital panel was dark and no power available to the unit. I have pushed the...
Hello Susan, Welcome to FixYa. Have you checked to see if perhaps one or both of the fuses may have blown at the back of the unit...I don't mean the hi-limit that you already referred to...I mean the in-line fuses the Asko machines are equipped with. Let me know and we can move forward from here. Regards, Macmarkus :)
Sep 12, 2010 | Asko T761 Electric Dryer
Acts like it has no power.
Check 230v at wall and back of dryer.
Check Breaker
Check Thermal switch (2 wires) at top of the element in back.(unplug the two wires from thermal unit and plug them together and try the dryer for a test
football shaped white,small fuse at bottom left in back of dryer
Do the same for a test.
If this was helpful please rate me.
Thanks
Leo Ponder
imufo2@sbcglobal.net
Aug 02, 2010 | Whirlpool LEB6300 Electric Dryer
My Maytag Quite Plus clothes dryer gets warm but not as hot as it use to. It seems to take a very long time to dry clothes. Vent is clear. The moisture gage seems to flicker lately.
most dryers have two heating elemts and when one goes out this increases the drying time and could cause a elec. short and trip a braker can be replaced.. There is also a saftey switch that goes bad and will not let the heating elemt work properly ?
Mar 25, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer will not start
Check the door switch. It acts as a safety and will not allow the machine to start. The Thermal fuse just keeps the heat form coming on.
Sep 19, 2009 | Dryers
Roper dryer model REX 3514RQ1. dryer works for/then quits. help!!
I have seen this before. You have got to remove the housing for the filter. Blow out the area around the blower and get the junk out of there. Wash out the filter housing.
Jul 06, 2009 | Dryers
My whirlpool heavy duty dryer just quit working all of a sudden
make sure you are getting power first then check to see if the belt is broken
Apr 21, 2009 | Dryers
Dryer not drying clothes anymore!!
Get the power company to send a repairman out there. The power surge mess up the controls.
Apr 09, 2009 | Whirlpool ET8CHEXSQ Dryer
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
Dryers Logo
64 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
