Question about Hitachi 53UDX10B 53" Rear Projection Television
Bow in tv
Tv bows down and up from the bottom and colors do not line up.
Had the covr board fixed but did nothing.
could it be the deflection board?
one resister is reading 2 ohms is that good or bad
resister colors are red ,white, silver ,gold
  • ernie trumpold May 11, 2008
    Is there a way to test the ic's
    Genius:
  • 1,139 Answers
Hello trumpold,
The bad new is the resistor is bad. If it is reading 2 ohms its bad because the rated value is .29 ohms and 5% tolerance. I would venture to say that the convergence amplifiers have gone bad. due to excessive current. Since the deflection and convergence boards work together they might both be defective. I would first suggest that you take the TV to a qualified TV repair shop, to perform the repair, but if you what to do this yourself you will need the following items:
1) Schematic of the TV in question (www.servicemanuals.net or www.manualsparadise.com
2) Signal Generator or use the on-board Signal Generator (look in schematic for usage.
3) Multimeter (for resistance, and voltage readings)
4) soldering iron, solder, and de-soldering tools (solder wick, and de-soldering pump)
With these items you should be able to determine the components you need to change, and remember follow the instructions in the schematic exactly as to board removal.
Before reinstalling the convergence board after changing out the convergence amps and ALL (I maen ALL) biasing resistors, check for solder bridges and shorts, removing them with the solderwick.
I hope this helps
Thank you,
Shuttle83
Posted on May 11, 2008
  • Henry McKelvey
    Henry McKelvey May 11, 2008
    Hello trumpold,
    The IC themselves can not be tested as if in a static test device, however you can test them by looking at the voltages an comparing them to the values in the schematic. also you could use a Huntron Tracker to compare it to a know good IC. These are the two way that you could test the ICs in question.
    I hope this helps,
    Thank you,
    Henry A. McKelvey
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Colors wont line up and will not manually adjust.Screen is also bowed. Last time this happened I replaced sub deflection board and this cured problem.I just replaced this board again did not fix problem
sounds like the power supply for this portion of the set isn't working this will result in a bowed picture with the colors failing to line up- check that the voltage that is supposed to be there is.
Feb 02, 2011 | Samsung Televison & Video
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
OUR SONY PROJECTION TV IS DISTORTING THE PICTURE BY BOWING IT IN AND ITS SHOWING RED AND GREEN COLOR DISTORTION. HOW CAN I FIX IT?
You will need to replace the sub deflection board or convergence I.Cs and check around the circuit for any o/c capacitors or resisters
Jan 06, 2010 | Televison & Video
BOWED PICTURE AND COLOR CONVERGENCE
You can replace the whole convergance board assy Part #239126 or 239126R and it should take care of problem.
Dec 18, 2008 | RCA P50830BL 50" Rear Projection...
Pt5598 rplaced convergence board no luck.
If the picture is still bowed, the power supply fuses are open.
Check the power supply on the red connector for + and - 20 volts.
The fuses are on the main board,are on the deflection module in the middle, tward the front of the TV. They should look like green (or brown) resistors. An ohmmeter check will show which ones are bad.
They should be 3.5 amps. Replace with 4 ohm GMA fuses with pigtails if you can't find picofuses. I also had a set that would fry the 1 ohm resistor on the 20 v supply. This was near the fuses.
I replaced the whole module to fix that.
I hope this helps. Lee, www.crazycomputers.com
May 31, 2008 | Akai PT5598HD 55" Rear Projection...
Help tv is showing double text at bottom and bowing colors
Convergence ICs are bad and need to b replaced there are two of them theyost about 10.00 each.
Jan 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Picture bowed on sides
how badly is it bowed on both sides? if it is too much. ther is a fuse resistor that is gone bad near the coil in the east west section. you need to replace that. if it is not too much..you need to get into the service mode to fix that..good luck
Apr 05, 2007 | Samsung PCK520R TV
Bow at top and bottom of the screen
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 10, 2007 | Samsung HCM5525W 55" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
43 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
