Question about Toshiba 50HM66 52" Television
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could be the cause of this?
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Posted on Sep 28, 2010
I have a mitsubishi tv model wd 60638 I changed the lamp. Tv works fine for about 20 minutes then I start to smell like something is burning then picture starts to flicker, what could could cause this
You have a bad connector in the lamp. Stop running the TV immediately and contact the company you purchased the lamp from. this is common in older DLP tvs but not in one 5 years old unless you have a lot of hours on it. the connector can crack and arc inside the plug and then melt and smell terrible. It usually very repairable if you can get a ballast for it. the plug is part of the ballast.
Aug 28, 2015 | Mitsubishi WD-60638 DLP TV
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
Have a wd60638 changed the lamp because old one busted now the TV works fine for about 3-5 minutes starts to hum and a clicking sound and pictures begins to flicker with colors going in and out
normally no bulb will bust ever unless you have oil on the lamp. sooo , it got too hot then. even if the fans turning its not putting out.
check the exhaust it should blow a lot of air past the lamp.
Oct 19, 2014 | Mitsubishi Televison & Video
Mitusbishi dlp tv shut off
hi when you replace the lamps, the lamp counter needs to be reset,thanks
shaun
Jun 28, 2017 | Mitsubishi WD-73737 73 in. HD-Ready TV
Wd65738 flickering
I had a TV do that about a year ago, the repair man said it was the color wheel inside the tv. I changed the bulb to see if he was BS'ng me and eventually got the manufacturer to send a color wheel and I change it myself, was very easy...TV works fine ever since. Hope this helps
Jul 10, 2012 | Mitsubishi WD-65738 DLP TV
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement....
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Jul 04, 2010 | Samsung HLP5085W 50" Rear Projection...
TV worksfine for one hour, colors fade in and out, flickers
Color Wheel, Go website Encmpass Parts Distr Look up the part # if they do not have it in stock then go to E-Bay look under Electronic 1-800-638-3328
Oct 07, 2009 | RCA HD50LPW175 50" HDTV
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Negative picture,lamp indicator flahing 3 minutes after turning tv off
I changed my lamp in the 65dr650 but the picture still looks like a black and white tv and flickers
Jan 30, 2008 | Sharp 65DR650 65" Rear Projection...
Toshiba 50HM66 52" Television Logo
211 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
