Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My garage door opener is not going down with my remotes but it will if I hold the button on the wall down.
  • robert blanchette
    robert blanchette Sep 03, 2010
    You need to check the sensors. They are probably out of alignment. They have to look at each other. There should be an led light on each of them and both should be on. There is a wing nut to adjust. Thanks BB
    President:
  • 3,197 Answers
Check the door sensors. Them must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit.
Posted on Sep 03, 2010
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
The garage Remote control was working normally at first then for now reason now it just opens the garage door but doesn't close it. I checked the side sensors they look OK & clear, and I...
It could be the garage door motor that is acting up. Try closing it with the button in the garage. If that's not the case, you may need a different garage door opener.
Jun 06, 2011 | liftmaster Garage Door 1/2 Hp
The garage door will only go down if I hold the button attached to the wall down until the door is completely closed. It will not go down with the remote control in the car . This started last week. Also I...
HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
ARE THE EYES WIRED CORRECTLY?
ARE THEY AIMED AT EACH OTHER?
Jul 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote control for garage door suddenly stopped working.
Press and hold for 3 seconds the button on the wall control with the lock icon. There you go.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman Garage Door remotes do not work. 139.663953
On the rear of your motor unit near where all those white wires go you will find the smart/learn button. Hold the button down on your remote and press and immediately release the smart/learn button. Do this with all your remotes.
Sep 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sear garage door wall mount contol light keeps blinking
Hold the button with the lock icon in for 3 seconds. This should toggle the unit off vacation mode and your remotes will work.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door wont go down.I habe to hold the switch down but if i let it go the door will go up again.
I have a Liftmaster garage door that won't go down unless you press and hold the wall button. The sensor lights are both on. The green light on the unit flashes unless I press the reset button. As soon as you press the wall button it flashes again and the door won't go down unless you hold the button the whole time. The remote wont' make it go down either. It begins to sometimes and retracts, but sometimes the light bulb just flashes (like it is obstructed). I tried replacing the wall switch and that did nothing. Help!
May 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Pressing remotes the door won't go u[
It sounds like you have the lock enguaged. When it is flashing it locks out all remote access. Hold the lock button for 3 seconds. The green light should go solid. On the issue of closing, it is most likely a safety eye issue. Hold down the wall button. If it closes it is the safety eyes. Holding the button overrides the safety eyes. Make sure that thelight on both eyes are both lit.
Jan 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
When remote or door switch is pressed the garage door opener only clicks, the motor attempts to move very slightly. starting capacitor is new.
SOUNDS LIKE A SAFETY EYE PROBLEM.
WILL IT CLOSE IF YOU HOLD DOWN THE WALL BUTTON??
Jul 09, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
73 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
