Question about GE Security Simon 3 Wireless Home Security System
Trying to add 10 window sensors to existing GE Simon 3 control panel that currently has just motion detect, glass break detect, and 3 door sensors. How to install and program them to work? Thanks you, Steve
    New Friend:
  • 74 Answers
First you need to have the installer code. Open the fromt panel of thealarm and enter in "4-3-2-1" (Default installer code) If it accepts this number then you can begin to program the doors and windows. If you don't knowtheinstaller code you mayneed to default the system and reprogram everything. If you contact meIcan walk you through the processor.
AlarmProfessor.com
Posted on Sep 05, 2010
Simon 3 motion sensor
If your motion detector act like a door it is because it has been program like a door, you need to go back to the program delete your sensor, and reprogram it with a group 17 , right now it's probably program as a group 13 ( instant)
Feb 11, 2013 | GE Security Simon 3 Wireless Home Security...
Hi! Just had ADT install security system and it is a Simon XT. Door units, motion sensors and control unit are in house. They also put a motion sensor in garage, which is detached. My understanding is...
My understanding is that GE does not produce a wireless interior siren any longer. So if yo want to get a siren in the garage a wire will have to be run from the Simon 3 to the location in the garage where you would like to place the siren. PS ADT will not run wires to a detached garage. GL
Nov 16, 2010 | GE Security Simon 3 Wireless Home Security...
I have ge simon 3 - Purchased ion micra -g wireless window and door compatible sensors. Didn't come with how to add sensor. Wants me to push button on sensor; where is that button
I'm having the same problem on a used Simon. I think the button is inside the wireless transmitter. It has a spring attached to it. Just press on the spring to send wireless signals to the panel. My problem is I press on the spring and the panel does not receive the signal, even with a $20 fresh Lithium Ion battery from Radio Shack.
May 15, 2010 | GE Security Simon 3 Wireless Home Security...
I have the Simon 3 security system with one motion detector installed. I didn't set this system up but would like to add another motion detector and was wondering how hard this is to program it into the...
I don't of any system that is simpler to add a device to. The process is in the manual and is something like press "add" on the panel, follow some prompts and press a button on the rear of the motion sensor. Pretty easy if you dont have keypad phobia. Electronic version of the manual is at this location (adding a sensor starts on page 18).
http://www.home-technology-store.com/assets/PDF/GE/Simon-Install.pdf
Mar 19, 2010 | GE Security Simon 3 Wireless Home Security...
Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
Jun 25, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon XT panel lights window, door and motion indicators
It sounds like the auto-stay arming function. Try arming it and opening and closing the door.
Feb 10, 2009 | GE Security Simon 3 Wireless Home Security...
GE Simon 3 Add or Change a Sensor to my system?
You need to use an installer code to add/remove sensors. Depending on what number of digits your alarm code is set for will determine the number for the intaller code. Look in the installer manual for the code. Then follow these steps:
Open the panel.
Key in installer coe
Select Add
Select Sensor/Remote
Activate the sensor you want to add. Some sensors have a button, some have to opened to activate.
Choose sensor name and group. Groups are listed in the manual. Basically, if you want the sensor to arm when the doors arm (such as for a window sensor or door sensor) put it in group 10 or 13. If it's a smoke sensor, group 26; motion detector, group 17 and keyfob, group 01.
Press done when finished and run the test to make sure the system is reading the sensor.
Oct 06, 2008 | GE Security Simon 3 Wireless Home Security...
REPROGRAMMING HELP
go into the simon, 64321 tech code then delete and the sensor button until it tell you which one you are on and then hit done..that deletes then to ad back depending on which sensor you are using , by hitting add then sensor and going to the room or door or what ever till you find the room and here is a list of all the setting for sensors smoke 26, d/w 13 no delay 10 delay, motion, 20 delay 17 no delay depending, shocks 13 on windows always 13, glass break 14, carbon 26, keyfob 01 there are more but these are most common
Dec 30, 2007 | GE Security Simon 3 Wireless Home Security...
GE Security Simon 3 Wireless Home Security System Logo
470 people viewed this question
Top GE Home Security Experts
Sean
Grantec 2000
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a GE Home Security Expert? Answer questions, earn points and help others
