Question about Toshiba Televison & Video
Hi I purchased a DV713B series Toshiba combi TV/DVD a week ago. It has been working fine however when I turned it on today the screen was completely white and showed no image but I was receiving sound. This also affected the DVD player. I was wondering if this was a common problem and if anyone knows how to fix it. I have tried turning it off at the mains and ensuring that all the power cables, aerial cables etc are all plugged in.
SOURCE: Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Posted on May 03, 2008
SOURCE: bush tv/dvd combi
your daughter has done nothing wrong, certain dvd,s have region codes for different can program the player with your remote, but you will need the hack number.i,m looking for it myself, so if you find it,pass it on!
Posted on Nov 25, 2008
SOURCE: Toshiba MW20F51 tv won't turn on either manually or with remote
power off all the time
Posted on Mar 12, 2009
SOURCE: Sunia LTD-1510 TV/DVD-problem w/ TV signal and sound
Do you have a schematic diagram of TV mine is broken as well
I have two of them
Posted on Apr 02, 2009
  • 56 Answers
SOURCE: MY toshiba tv MW27F11C only shows a white line when turned on
Hello uuka,
You have vertical collapse. This is most often caused by a defective vertical output integrated circuit, an open dropping resistor which feeds the supply voltage to the I.C., one or more defective electrolytic capacitors in the vertical circuit or something as simple as bad solder connections. The latter will usually manifest itself as an intermittent failure. Less likely, but stilla possibility is a defective yoke, but this a rare.
Unless you are handy with a soldering iron and have some experience this is definitely something I suggest that you refer to a qualified technician. Depending on the actual cure for the problem, this would typically be under $100 in my shop, but we are in a small town and prices are cheap. I would definitely recommend a repair on this since it can not be replaced. They don't make a TV/DVD/VCR combination any longer and the picture quality on these Toshiba/Orion combos has been very good over time.
Hope this helped and don't forget to rate...
The Wing Guy
Posted on May 04, 2009
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
About 2 weeks ago my dell 42" plasma started
change your tv main board, your tv board was broken
Jan 16, 2011 | Dell W4200 42 in. HD-Ready Plasma...
Bought a Toshiba Regza 37rv635d last week.
I have had the same problem today. I think it might be to do with the master power button on the side, as it seems loose on my tv. Did you ever solve the problem on yours?
Apr 06, 2010 | Televison & Video
Toshiba dvd rom
Toshiba Satellite 1400 Series DVD/CDRW Combo Drive (P000347430)
hope that helps
Jun 11, 2009 | Toshiba Satellite A105 Notebook
Mitsu 57731 problems have wide bar across screen
This is an ongoing problem with Mitsubishi DLP HDTV's contact the Customer Service at 1-800-332-211. Tell them this has been going on for a while and you want the TV either Fixed or Replaced. Ask for Adrianne Hardt, she is a Customer Service Manager...... TELL HER RICK GRIFFITH told you to call.
I am in the 4th week negociations with Mitsubishi over these exact problems. I purchased my 57" DLP HDTV in Aug of 06. Replaced the Lamp 3 times and have had 5 Service calls. I DO NOT have and extended Warranty. Mitsubishi provided me with the extention in writing and stated if any problem occurred again they would replace the Unit or provided monetary compensation.
Good Luck and be persistant.
Any of you can email me for from info and
Feb 23, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Missing Manual
I found the manual on the Target website. Now I just need to find a remote that will work with the TV. cheers
Oct 07, 2008 | Toshiba MD20F51 20 in. TV/DVD Combo
Toshiba 50hp66 picture waves
Please describe the 'waves' and what you are watching when it happens, is it on everything? e.g. normal TV and when watching a DVD? Are the Waves a grey close pattern going diagonally across the screen for some other sort of pattern?
Jun 13, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
DVD problem with Toshiba TV/VCR/DVD Model MW24FP1
I've only had mine for 3 years- DVD didn't recognize 2 out of 3 discs or would cut out- started about a year ago. Today the whole picture went out. Just don't make them like they used to
Mar 04, 2008 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
RCA tv
Check the signal type. It may be set incorrectly. Change the channel. You may be on a blank channel. Check to see if the TV is tuned to channel 3 or 4 if you are watching a videotape. Check the TV/VCR button on the VCR is in the correct mode by pressing the TV/VCR button on your VCR.
Aug 11, 2007 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Tv will not turn on
your tv needs to be repair again power supply problem or circuit.good luck.
Apr 04, 2007 | Toshiba 37HLX95 37 in. LCD TV/DVD Combo
Televison & Video Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
