Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
Light is out in 650
The light was going on and off- both the bulbs and the backlight for the display. now they are both off and i cant figure out how to reset. i can get new bulbs but that will not fix the backlight problem on the display. any tips
  • Leslie Dressler Aug 25, 2013
    I'm having the same problem. The switch checks out OK but I'm only getting 2 to 3 V across the terminals. Defininitely not enough voltage to light up the bulbs and display. Anybody have any ideas?
    Problem Solver:
  • 7 Answers
Check continuity on door light switch with ohmmeter (turn off power and disconnect wire harness at switch first) Probably a second switch that turns compressor off if door open. my 690 sub zero had a bad light switch that was stuck on initially but now only works if I wiggle it. Can a person buy parts online? Some new subzeros have a fuse panel behind the compressor grill??
Just bought a used 690 and found a nice wiring diagram for a model 630 or something in a nice ziplock pouch behind the compressor grill. Look there for clues.
Posted on Jun 01, 2008
Display is very dim
Backlight bulb is burnt out. The display, on its own, will not generate enough light to read so there is a backlight bulb that brightens the display. Need to disassemble and see what type bulb is in there. Radio Shack should have a replacement if you bring your old one it.
GOOD LUCK>
May 25, 2016 | Audio Players & Recorders
TK 760H BACKLIGHT NOT WORKING HOW DO I FIX IT
This is common for these older radio to burn out light bulbs. Do a google search for the service manual, it will show you how to disassemble the rig and what bulbs you need, many of these mobiles are an absolute nightmare to replace the bulbs yourself
Sep 04, 2014 | Radio Communications
Change bulb on vstar 650 on speedometer
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/19241-speedometer-light-bulb.html
Star 650 Light Bulb Installation
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Apr 19, 2012 | 2000 Yamaha V Star Classic
Screen comes on during startup for only a second or two, then display shuts off, not the power light. if i try to power it down then back up it doe the same thing. so i figured its a capacitor so im trying...
That issue is normally caused by the backlight in the LCD. The compact florescent light in the display is burning out. They will normally light for a few seconds when first powered on, then shutoff.
Ultimately, the bulb needs to be replaced. If your into hacking electronics, you can get a replacement bulb online and DIY. Otherwise, the cost of having it repaired is usually very close if not more than a new monitor.
Dec 05, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
My screen on my laptop just went all black with a very faint image. what is wrong there, how do i fix it, and what made this happen?
A) What is wrong?;
Your Backlight has gone bad, or the Inverter.
B) How do I fix it?
Replace the Backlight bulb, or the Inverter
C) Backlight bulb's, and Inverters, like everything have a 'lifespan'
This one is at the end of it's. (Stating the Backlight or the Inverter
From here all I can give you is Generic information, since I do not have the laptop manufacturer name, and Model Number. This is on the bottom of the laptop.
1) An LCD screen cannot produce enough light by itself. A Backlight bulb, (Or more than one), is used to emit enough light.
2) A laptop cannot produce enough power to power the LCD screen, and is also used for power to the Backlight.
I'll have to discuss the way the Display Assembly is put together, and name parts in order to explain the following of how to repair. Again, generic information.
1a) The plastic top of the laptop is the Top Cover. There are different names used by different manufacturers.
1b) Looking at the LCD screen with the laptop open, there is a plastic frame that goes around the edges of the LCD screen, and is in Front.
This is the Display Bezel
1c) The LCD screen is behind the Display Bezel. The LCD screen is a composite of layers. The outside layer that faces you is a protective screen.
Around these layers composing the LCD screen, is a metal frame.
One side, (Or both sides) of the metal frame is removed to access the Backlight bulb.
1d) The Backlight bulb is a CCFL.
Cold Cathode Fluorescent Lamp.
Very similar to the fluorescent lamps, (Bulbs) uses in residential, and commercial applications, but on a MUCH smaller scale.
Now to show you generic laptop info on replacing the Backlight bulb for them.
A) http://www.insidemylaptop.com/category/backlight/
B) http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
If I had the laptop manufacturer name, and Model Number, I could try to give you a link to the Service Manual for the laptop. (Free. Usually from the laptop manufacturer)
This way you would have Exact info on how to disassemble your laptop's Display Assembly.
Post in a Comment.
Oct 13, 2010 | Computers & Internet
My laptop screen will not say on for a normal time period. I change the inverter board but the screen still turn off. Why?
you are getting display when the backlight bulb of the monitor is working,when the back light bulb is going off you are not getting the display... in some computer the backlight bulb of the screen is the part of lcd screen assembly..your computer model has got one CCFL BULB WITH DISPLAY ASSEMBLY..The item number of your comput's lcd is - NXK702-0293,resolution-WXGA+(1440*900),type-Matte,backlight connector-2 pin,video signal connector- 30pin
Sep 16, 2010 | Toshiba Satellite P35-S6111 Notebook
Toshiba P10 laptop screen no longer works.
It's not the inverter but the biotin backlight bulb that lights the display from underneath. The screen needs to be replaced unless you want to try and rebuild it and replace the backlight bulb. New screens from EBay should not be more than 70-100 bucks. If you want to try and replace the backlight bulb, the link is below for the procedure.....
Nov 03, 2009 | Toshiba Satellite LP154W01 Notebook
LED light dont come on!!! Pioneer audio receiver VSX-9700s
Do you mean that the display that show the audio source or mode doesn't turn on? Try shining a bright flashlight at the display and see if you can read it. If you can, then the backlight light bulbs have died.
Replacing it will be a pain but you may find a usable replacement at Radio Shack. Just measure the voltage that goes to the bulbs and find one with similar ratings. They are probably 12v lamps.You will need to remove the display from the front panel of the amp and desolder the old lamps. Getting at the bulbs is the hardest part.
Dec 25, 2008 | Audio Players & Recorders
99 ford expedition radio problem
This is not a fuse problem, it is a burnt out display backlight bulb, you have to pull the radio out of the dash and remove the top cover of the radio, you will see a tiny bulb socket, twist it out, replace that little bulb.
Oct 13, 2008 | 1999 Ford Expedition
Laptop screen
try to figure out what the picture says than go from there.
if you cant see the picture, than go into the screen section of your laptop and than try to up the colour in the boxes there.
Jul 27, 2008 | HP Pavilion dv1000 Notebook
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
350 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
