Question about Multiquip GA25H 25kW 120V Honda GX160
Governer control link assembly for GX160 small honda engine
Revs really high
The gx160 has flag control on air intake to carb.
The flag is spring loaded to return to idil .
the spring has came off/ the cable has bunched preventing free movement.
long nose vice grips and gently reline.
Jun 09, 2014 | 5.5 HP GX160 Engine
This is a honda gx160 driving a generator. Engine starts OK but when any load is put onto generator engine splutters then stops. Display says low engine power. Any ideas?
check oil level .low oil causes vacuum in the carb, causing fuel starving .
also check capasator has not blown in generator .
Jan 16, 2014 | 5.5 HP GX160 Engine
Honda GX160 starts runs dies
How about the carb was it cleaned ???? It's definitely a fuel issue
Dec 16, 2012 | 5.5hp 6:1 Gear Ratio GX160 Engine
Why does my honda gx160 start and run for minute or two then cut off. Will restart
Hi, check the oil level. If low the oil guardian is cutting the spark. Regards Phil.
Aug 19, 2012 | 5.5 HP GX160 Engine
What is the valve clearance on a honda gx160
Valves are set at 0.15 intake and 0.20 exhaust (metric)
Jul 25, 2012 | 5.5 HP GX160 Engine
My honda 5.5 gx160 generator wont start
Is the ignition switch turned to "ON" . Is it full of oil?
Apr 23, 2012 | Honda Horizontal Engine 5.5 HP OHV 12V ES...
Pressure washer with Honda GX160 5.5 HP OHV-Starts easily but...
what about the linkage between the governer and the carb. Is that working and not binding?
Dec 20, 2009 | Honda Pressure Washer PSI 3000
Multiquip GA25H 25kW 120V Honda GX160 Logo
90 people viewed this question
Top Multiquip Electrical Supplies Experts
JonSnell Electronic
JonSnell Electronic
Lucy Angela
Lucy Angela
Are you a Multiquip Electrical Supply Expert? Answer questions, earn points and help others
