Question about Dell E173FP 17" LCD Flat Panel Monitor
Monitor has green start button on but does not hold the image. Speakers have audio But monitor. Has no image. When button is turned on the image comes on but quickly disappears
  • 11,361 Answers
It can be cold solder joints, transistors, caps. Worst case will be lamp assembly (I do not run into bad lamp assemblies much in Dell monitors)
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Sep 03, 2010
  • 131 Answers
Press the auto adjust button. If that does not work, boot into Safe Mode by pressing F8 at computer boot. If this occurred after an update, roll back the driver on the display adapter.
How do I activate the sound for my monitor (CM2019). Our old speakers broke and I want to use the speakers in the monitor.
On the back of the monitor, look for a small jack with green color with the 'AUDIO INPUT', 'AUDIO LINE INPUT', then you will need an audio cable with mini stereo phone plug at each end (get it from Radio Shack). One end of the plug will go into the monitor AUDIO input (green), and another end will go into the PC AUDIO line out (Green jack) just like where your old PC speaker cable was plugged into. You need to set the volume level on your monitor to about mid point first and redjaut it later on.
Picture of the audio cable with pugs.
Aug 22, 2010 | Balance CM2019 19" LCD Monitor
How do I turn on monitor speakers
Hi Anonymous,
Typically, the speakers need to be plugged into the green audio port on the back of your computer, or use HDMI cable, if your system can use one.
May 20, 2010 | X2Gen MG17J 17" Monitor
Image is off center bottom is cut off so I cannot see commands
This page is for ACER products. Select the DISPLAY, the choose the correct model for your monitor. There select Guides and Manuals. When you get the PDF file open, look for ADJUSTING DISPLAY SETTINGS. (page 6)
This is what was one one product's manual. This is similar to what my HP monitor uses. Hope this helps.
User Controls
A brief description and the location of all LCD Monitor function controls and indicators:
Figure 2-1
Stereo Speakers
PC Audio Stereo output.
Speaker Volume Control
Increase Volume - Turn the knob clock wise.
Decrease Volume - Turn the knob counter clock wise.
DC Power Switch
Press the power switch to switch the monitor ON/OFF.
DC Power-On Indicator
LED lights Green color --- Power is ON.
LED lights Yellow --- Monitor is in "Power Saving Mode".
LED is off --- Power is OFF.
5
Function Select Buttons
Press either left or right control button for OSD (On Screen Display) menu selection.
6
Adjustment Control Buttons
Press the left button to decrease the OSD setting and press the right button to increase the OSD setting.
7
External Headphone Jack
The monitor speakers will be disabled when using an external headphone or external speakers.
Good luck
Feb 18, 2010 | Acer Computers & Internet
Have installed a new monitor and cannot get any sound
Hi.
Silly Question. Moitor does have speakers, it has happened in the past!
Ok! you have speackers. Go to control panel click sound icon (Speaker).
Tab sound, choose exit to test, click square button you should hear sound, remembering too insert jack plug in the correct hole rear of your poota(Usually GREEN)
Nov 12, 2009 | Computers & Internet
Hp monitro speakers not working
Hi!
I think the sound drivers of your monitor may have got corrupted after formatting and hence you are facing the issue of speakers not working. Please try to rest the Monitor by turning off the monitor then press and hold the menu button and while you are still holding the menu button turn on the monitor and hold it still for 2 minutes. If the problem persists then you need to download the new drivers for your monitor from hp.com and install them to resolve the issue you are facing with.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 16, 2009 | HP w17e Monitor
How to use speakers
If your monitor has built in speakers then there should be a small jack in the back, usually green in color. You would need to run an audio cable from the monitor to the proper jack on the back of your computer, usually the green color like on the monitor. Once connected you should be able to use the volume button on the monitor to adjust to your preference. But remember external speakers are usually a higher quality than those built in to the monitor. Hope this helps.
Jul 11, 2009 | Relisys TL565 15" LCD Monitor
No audio in monitor internal speakers.
Make sure the cable that goes from the monitor to the computers green audio jack is connected.
Check that the monitors speakers are not muted(see if there is an option to do that by pressing certain buttons on the monitor) ,finally make sure the sound on the computer itself is not muted or too low.
Mar 27, 2009 | Dell Microsoft Windows XP Home Edition
Viewsonic VE175b Monitor Powers Up Doesn't Display Windows OS
Hi; I had the same problem. I know that sometimes devices require you to perform some type of '10-30 second' "hold" of one or some of its buttons in order to 'reset' the device, so to speak. So, having said that, try this:
1) Turn your monitor off (no green light) but leave it plugged in.
2) Leave it off for about 10 seconds.
3) Hold the [2] button on your monitor (the one to the immediate LEFT of your monitor's POWER button).
4) While holding the [2] button, now press and HOLD your POWER button.
5) Wait for your image to appear and STAY onscreen for about 5 seconds, then release both buttons.
6) Your monitor should retain its onscreen image.
Hope this helps! Good Day to all!
Kelvin W.
Dec 04, 2008 | ViewSonic VE175b 17" LCD Monitor
No sound from monitor speakers. Worked fine for 5 years. Can hear sounds when using headphones plugged into CPU. Hope you can help even if only to tell me I need a new monitor. Sincerely Dizzyme.
Hi...there,
First of all, check if your audio cable are still plugged into the monitor and pc output (light green) audio jack. If not just plugged it back in... Still still got no sound... Then turned off the monitor and pc. Unplugged all the cables from the monitor and pc, wait for 10 second till all the surged built up are cleared out. Then you can plugged all the cables back Monitor should have 3 cables, a audio cable, a VGA or DVI cables, and a power cord... OK! now you got all the cables plugged back in...
Turned on the monitor and PC....and a few seconds....you should hear window started. Still... had a problems....just get a external speakers. Have nice day!
Oct 08, 2008 | Hansol H550 15" LCD Monitor
Installed new monitor, lost my sound
If your previous monitor had built in speakers and your new monitor does not you are going to have to purchase new speakers. If your new lcd monitor has an audio input you can purcahse a sterio mini jack cable for under $10 at any store that sells computer stuff (circuit city, best buy, walmart, target, etc). Simply plug one end into your monitor and the other end into your computers audio output jack (usually color coded green). Now of course if that monitor does not have built in speakers your only option is to purcahse a set of speakers for the computer. These usually start at around $15.
Aug 10, 2007 | LG Flatron MW-30LZ10 30" LCD Monitor
Dell E173FP 17" LCD Flat Panel Monitor Logo
46 people viewed this question
Alun Cox
