Question about Gateway M675 Notebook
I have a gateway m675 and it has something wrong with the lcd screen. In the right hand corner the is a band about 2' wide and runs top to bottom. The colors are inverted looking that area and the tint of the rest of the lcd are off too. I plugged it in to external monitor and it showed just fine. Im not sure if the problem is the lcd, inverter, or the cable.
    Guru:
  • 1,082 Answers
I would place bet on the LCD going/gone bad. If it works with an external monitor that is about all that is left. Google LCD replacement for screens.
Posted on Sep 03, 2010
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
Describe your Gateway M675 Laptop w/ Pentium4 Gateway M675 won't maintain a charge after charging and the display flicks from ac/dc until the battery is completely empty. Do I need a new battery or power...
Sounds like you need a new power adapter.The M675 needs the correct voltage constantly to work correctly.I'm using one right now and it does the same thing with the wrong adapter or a weak adapter(low voltage).M675 is a great laptop but with the 3.0ghz its got to get the power it needs especially when its under a heavy load.
Oct 26, 2010 | Gateway M675 Laptop
My Gateway M675 laptop doesn't allow me to display video on an NEC np61 projector...I connected the cables before turning the PC back on and I see the Windows screen, but not the video...
Here is a direct link to the user's manual of the M675:
http://support.gateway.com/s/Manuals/Mobile/9528976.pdf
On page 65 of this manual, there is a detailed description of how to get this laptop to work with projectors.
Nov 06, 2009 | Gateway M675 LAPTOP LCD HINGE/CLUTCH (L+R)...
When it is turned on my screen is white everything is working .
Is the screen fuzzy? i found this solution on Google when it happened to mine. Try pressing hard just under the bottom right hand corner of the screen with your thumb (and second or third finger on the top). Squeeze hard! it works every time for my camera. hope it works for yours. Good luck.
Jul 01, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Grey transparent vertical band centre of screen
enter the bios nad set the keyboard option to unlock
Oct 23, 2008 | IBM ThinkPad R50e Notebook
Grey transparent vertical band on laptop screen
This problem occurs due power fluctuations and over heat .You have to change the laptop screen .No other way to go..
Good Luck
Siju.D
I flashed the bios on my gateway m675 and it stopped working. It turns on but screen is blank. If I hook it up to an external monitor I can get into bios. Is there anyway to get it back to the way it was?...
pls check the bios set up externally if you mistakenly turn the brightness down, and correct it
or see if ther is any brightness button you accidentally pushed on the top of your laptop
or ther could be some problem with your LCD inverter or the LCD itself.
Aug 08, 2008 | Gateway M675 Notebook
Purple band
It lloks like the video cable or inverter may be bad. Worst case scenario is the LCD may be bad. Try replacing cable or inverter first.
Jan 06, 2008 | Acer TravelMate 2300 Notebook
Yellow stripe down the screen.?
And a good evening to you!
It is possible that you have a bad LCD assembly, or possibly the LCD cable connector is loose. The only way to find out is to remove the LCD assembly from the top cover so that you can access the connector. It is located behind the LCD screen.
If you want a copy of a service manual for the disassembly process, let me know and I'll see what I can do for you.
Ron-
Dec 01, 2007 | Acer Aspire 1642WLMi Notebook
Gateway M675 creen problem
Yes you are correct and they are beggars to fix.  Your problem is fixable just ask these chappies:
http://lcdrepair.net
Oct 10, 2007 | Gateway M675 Laptop
Gateway M675 Notebook Logo
143 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
