Question about Refrigerators
Refrigerator not cold enough
The freezer is fine, but the refrigerator is not keeping food or liquids cold.
  • 1 more comment
  • Artvulture May 16, 2008
    Freezer is fine. Air is blowing. Refrigerator is not getting cold enough.
    Very little air blowing in frig.
    Condensor gets very hot. Hot enough for the coils to singe the wall.
    Whats the problem?
  • Anonymous Sep 01, 2008
    freezer fine, refrigerator cant get my beer cold enough, kids complain about warm milk.
  • Lullaby4u Nov 30, 2008
    No frost build up on any freezer walls - freezer is freezing just fine - can't get the refrigerator cold...
  • 770 Answers
Check the back wall of your freezer for a heavy frost build up rhis is an indication of a defrost problem also make sure the fan in the freezer is working
Posted on May 11, 2008
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Refrigerator section does not keep food cold enough
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 24, 2010 | Fisher and Paykel E522B Stainless Steel...
Refrig. Won't keep food cold but the freezer works fine. Milk spoils after 3 days in the refrigerator. What's wrong? The thermastat was supposely changed?
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
May 07, 2010 | Refrigerators
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Freezer is not keeping food cold enough. Could it
ck to be sure light is being turned off when door is closed. Work the switch.
Jan 28, 2010 | Amana ARS266ZBS Side by Side Refrigerator
The food and drinks in the refrigerator does not feel and taste cold enough. The freezer is just fine.
Check for proper operation of the freezer fan. This fan moves cold air from the freezer to the refrigerator. If the fan is not turning, the freezer will be too cold and the refrigerator will not be cold enough.
The fan should be behind an access plate at the rear of the freezer. Listen for the sound of the fan. If you can't hear it, remove the cover and look at the fan. If it's not turning, you will need to replace the fan motor.
Oct 15, 2009 | Maytag MZD2766GES Side by Side...
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
Freezer compartment on refrigerator not cold enough
depending on the temp it could
if the ambient temp get below 32
you freezer wont come on and actually begin to get warm (insulation factor)
but the refer will seem cold because of the low ambiant temp is the temp inside
we go in the refer alot more than the freezer
Mar 28, 2009 | Frigidaire FRT21S6A Top Freezer...
Freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Refrigerators Logo
512 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
