Question about One For All URC4220 Remote Control
Remote codes need codes and instructions for one for all remote zenith tv
    President:
  • 2,712 Answers
Zenith codes: 0017, 0016, 0092
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 17, 2008
**** ur mom
Posted on Jun 21, 2008
I need a code for my tv zenith i have a jumbo remote laxmax
Hello
Three digit remote codes for Zenith TV with Innovage Jumbo remote control are:
004 / 005 / 006 / 019 / 196 / 004 / 051 / 083 / 152 / 153 / 154 / 210 / 217
OK.
Jun 20, 2011 | Innovage Jumbo Remote Control
I need the code for zenith tv to enter into jumbo remote, lost instruction manual
You can download the manual for your remote here:
http://files.remotecentral.com/view/360-531-1/innovage_jumbo_remote.html
ZENITH TV Codes are 000,001,004,023,
038,058,059,064,
073,121,135,136,153
One of these should work, good luck!
Mar 01, 2011 | Innovage Jumbo Remote Control
I need the Zenith remote control code for the 1986 Zenith TV
joe, the remote control codes are not the same from vendor to vendor. I think you're trying to program a universal remote control to operate your tv, if this is so, you will need to get the model number of the universal set and refer to the product code list, look under tv and zenith, another procedure you may try is the code search, this puts out all the available codes programmed into the universal set, just follow the instructions and be very patient because like I mentioned it will take you through all the available codes untill it will send the correct one for your zenith tv.
Feb 10, 2010 | Televison & Video
Control code
leoidalgo
I have provided the remote codes for your Zenith TV. I have also provided a link with instructions on how to program the remote to the TV. I hope this helps.
Remote codes: 501, 652, 766, 500
Program remote, step 6:
http://www.dishnetwork.com/SupportSection/remote-setup
Ray Calo
DISH Network
Jan 06, 2010 | DISH Network 142923 Remote Control
All for one universal remote with no codes for a Zenith TV
The link below will take you to a page on the One For All website where you can enter the model number of your remote and receive Zenith TV codes and instructions on how to use them.
http://www.oneforall.com/en_UK/support
There are so many models of One For All remote controls, I cannot give you codes and instructions for all of them.
If you have a URC-3021, then the Zenith TV codes are 0017, 0463, 0178, 0092.
Sep 20, 2009 | One For All URC-3021 Remote Control
Need codes to program a zenith tv
I found that this website should have all the codes and instructions for most remotes
http://www.xdiv.com/remotes/
or http://www.remote-codes.com/
Jun 12, 2009 | Zenith ZEN400SP Remote Control
Programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
Oct 27, 2007 | Zenith DBZN-311 Remote Control
Zenith ZN-501S remote control codes and instructions
From the ZN5015 code manual for Quasar TV 007 107 416 608 618 718 807 901
Apr 15, 2007 | Zenith ZN-501S Remote Control
One For All URC4220 Remote Control Logo
1,287 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
