Question about Pioneer DEH-P2000 CD Player
Error 10 Just installed this unit in my boat. Radio works fine, but when I put a disk in it spins for awhile and then the display reads error 10. I got this unit from my son when he pulled it out of his car and I have info on it. Any ideas?
  • delroymyers Sep 03, 2008
    i bought a pioneer car radio from a dealer,and he tested it at the store,and it was working.installed it in my car,it work for a while and then stop,then FRMTREAD came on the face of the radio,then error 10.how can it work as norm.
    Problem Solver:
  • 20 Answers
E10 i belive is an unreadable disk i.e. dirty or scratched. Depending on the model of radio, they are sesitive,
Posted on Aug 07, 2008
Car radio cd player error 43
The motor that spins the disk no longer works, disassemble the cd player and replace your cd motor with a new one. Radio shack has them, but I suggest replacing your player with an aftermarket unit like sony, kenwood, audiovox, or any other high quality cd players.
Dec 07, 2013 | Hyundai Cars & Trucks
Error reading any dvd disks
Have you tried a DVD+/-RW ?
The noises that you are hearing will be the spindle motor trying to spin the DVD as the lifting presentation tray for the read/write head has not located, if the media is not spinning this will never be able to read the lead in on any DVD as it has not presented the disc in the correct place.
If is is out of guarantee then I suggest that you check to see if the DVD is spinning by removing the top cover with the power OFF then eject the tray and try to load the media a small touch of the DVD in the clockwise motion should cause the media to start spinning, this is for diagnosis only if this is the case then the spindle motor will need changing
May 28, 2010 | Panasonic DMRES15 DVD Recorder
Cd player doesnt work and states ''error 06''
If you all ready try cleaning the CD lens now the next step is disconnecting the negative wire from the car battery for about 10 min. but make sure that you have the radio code before disconnect the battery or make sure that your radio does not have a security code, if nothing happen after this try you must send the radio for repair usually they have to replace de CD lens. Good luck
Jan 02, 2010 | Car Audio & Video
Wont recognise any disk
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD or Blue ray lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
May 04, 2009 | Televison & Video
Pioneer Avh P5700
might need laser cleaning. try a laser cleaning disc from most electronic shops
Jul 19, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Error Code:DVD HO2
try to clean it first bring cleaner cd from radio shack. put your cleaning disk in and let it run-remove cleaning disk and put your disk and try,
Nov 03, 2007 | Panasonic SC-HT75 System
Jeep 10 disc changer; now only error message on dash.
I had this same problem on my 2000 Jeep GC Limited. Today I decided to open it up after looking all over the net and found no help, but spend $500.00 on a new unit. I removed the unit and used canned air inside all the areas I could. I hooked it back up and was finally able to make the CD cleaner disc work. Once that was done I loaded it with 10 cd's and it is working again. I'm so happy! I saved my hubby 500 big ones.
Oct 26, 2007 | Cherokee Jeep Grand CD Changers - 10-Disc
LG V8824
the small 12 tooth gear on top of the slide motor could have a crack in it , this will lock the slide from working
Sep 21, 2007 | Sony SLV-D350P DVD Player/VCR
Pioneer DEH-P2000 CD Player Logo
164 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
